94 Powerstroke Stalling need help? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 05-21-2008, 10:21 PM Thread Starter
Send a message via AIM to jsoundguy
Question 94 Powerstroke Stalling need help?
Okay please help read entirely still sounds weird to me. Have a 94 powerstroke 364,000 miles runs good accept, it stalls or hicups sometimes under electrical loads that shouldn't make it! If you are sitting at a redlight with a signal on it will try to hicup or sometimes stall when you are trying to take off. the main regular driving problem is the signals. it gets worse with a trailer and if you have the trailer brakes hooked up activating them will kill it every time. Other things that will make it hicup are hazzards, headlights, bright lights, brake being applied, interior light. It seems to be getting worse at night battery gauge is lower than usaul. The weird thing is the a/c radio don't affect it at all. more hicups at night but can happen anytime even changing lanes at 70 it hicups. Alternator is less than a year truck was doing this before and after it was installed one battery is about 3 years one is 2 years i think i have almost had the truck a year. I had the battiries checked a few months ago seemed fine they said. THis is my daily driver gets 20 plus on the highway don't tow much by the way all the specs it is a 1994 (built in june 94) powerstroke f-250 extended cab long bed 5 speed all stock except k & N in factory box 364,000 miles. Please HELP!
jsoundguy is offline
post #2 of 11 Old 05-22-2008, 10:42 AM Thread Starter
Any Ideas anyone please help!
post #3 of 11 Old 05-22-2008, 10:42 AM
Mine did the same thing. Does it fire right back up after it dies? For me it was the alternator. It was still putting out some juice but not enough so under high loads the batteries had to back it up. Since they didn't get properly charged any more either it acted up. Alternator test is free a Auto Zone and those places. If you have a Voltmeter you can check a little bit yourself. Check battery voltage with Truck off, should be a little more than 12V. Crank it, now it should be upwards of 14V (after glow plug relay has shut off), maybe a little below 14V with all electrical equipment turned on (High Beams, Fan to High, Max A/C). If it is only 13V or so your alternator is bad. If you replaced it before maybe you got one with lifetime warranty?
Good luck!
1997 F350 Crew Cab Dually 2WD PSD 5 Speed Short Range Manual
3' downpipe, Kitty delete, DIY NAPA Filter Intake, Edge Evo Programer on Lvl 1 for MPG
stinky is offline
post #4 of 11 Old 05-22-2008, 11:16 AM
Sam Burton's Avatar
have you replaced your cam postion sensor?
mine did wierd things like that, i changed the cps and it has been fine ever since.
1978 Ford Bronco
12v Cummins
ZF-5 NP 205 10.25 rear Dana 60 front
Denny T fuel pin 366 governor spring
HX 35 turbo BD exhaust brake
Powerstroke intercooler
1990 F-350 Crew-Cab Short Box XLT 4x4
Powerstroke E4OD
170cc stage 1 injectors, superduty intercooler, flowmaster 3" down pipe, 4" exhaust, 6637 filter, 17* HPOP, Wildman tunes, build E4OD, 5 disc billet converter, Irate E-fuel, 1.0 exhaust housing, WW2, CCV mod, homemade RSK
Sam Burton is offline
post #5 of 11 Old 05-22-2008, 12:22 PM
Send a message via AIM to kx592
its 100% the CPS
kx592 is offline
post #6 of 11 Old 05-22-2008, 09:22 PM Thread Starter
Did i hear someone say best place to get the cps is international and approximately how much?
post #7 of 11 Old 05-23-2008, 05:37 AM
I got mine at Autozone for around $30. But check with Ford first if your Trucks falls under the recall. They recently recalled a bunch of Trucks for that sensor and then they fix it for free. They even reimbursed me for my sensor I bought a few weeks prior to the recall so keep the receipt.
stinky is offline
post #8 of 11 Old 05-23-2008, 05:55 AM
you either have a problem with your alternator, battery, or your regulator either one of those could cause those problems bypass the alternator to check if the regulator is bad if it isnt most likely your alternator if thats good change your battery and if none of those work you gotta a problem with your grounds and you should prolly replace your batter cables and put in new ground cables
power73strokin is offline
post #9 of 11 Old 05-23-2008, 07:04 AM
SMKSTAX's Avatar
If you have a dealership close by a new CPS costs $21-22 dollars. The recall only covers back to 1997 trucks. Hopefully that's your problem because it's a cheap fix.
RICK
97 F350 CREW CAB 4x4, 7.3 TURBO DIESEL, DIY INTAKE , TW TUNES
GRAND ROCK POWERFLOW STACK KIT W/5" MITRES
3.55 REARS, 3" DOWNPIPE, FPR SHIMMED WITH GAUGE
SMKSTAX is offline
post #10 of 11 Old 05-23-2008, 08:02 AM Thread Starter
isn't there spme ford technicians on here anyone every came accross this problem need it fixed but don't have the money to fix a hundred things
