Throttle pedal problems... - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-24-2013, 04:53 PM Thread Starter
KS_
Quoted: 22 Post(s)
Okay, so I have had this problem for a while and I have became so used to it I almost forgot about it. When I go to push in the throttle it has a good bit of play in it. It instantly revs up to 1100 RPM. This doesn't seem right to me. My dad has the same year but a dually. No play whatsoever so I feel like I have a problem. He seems to think its the Cam Sensor but I think its the TPS, anyone have any suggestions? I had it throw a code one time where it completely wouldn't go anywhere when I pushed in the throttle and I had to turn it off to fix it and it shot a TPS code.. haven't had a problem since though after I turned it back on.
  • Kaleb - 97 F-250. 1.0 housing, WW2, 3 inch dp to 3.5 straight pipe, TS 6POS chip, Riffraff 6637 Intake, 4" Rough Country Suspension Lift and 33"s.
  • To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
KS_ is offline
post #2 of 6 Old 08-24-2013, 09:20 PM
Quoted: 43 Post(s)
Sounds like the idle switch on the pedal. Not closing soon enough as you press the pedal.
madpogue is offline
post #3 of 6 Old 08-25-2013, 01:13 AM Thread Starter
KS_
Quoted: 22 Post(s)
It also doesn't click like other obs's ive drove. Idk if that will help but I forgot to include that. So hopefully we can narrow it down to at least that one thing..
KS_ is offline
post #4 of 6 Old 08-25-2013, 08:47 AM
Patrick Feeley's Avatar
Quoted: 8 Post(s)
If you look at the pedal assembly, there will be two electrical connections to it. One is for the TPS (3-wire connection) and the Idle Validation Switch (2-wire connection). The IVS should be open at idle and close just off the idle position. You can check it with the IVS disconnected and a meter. Cheers!
Patrick Feeley is offline
post #5 of 6 Old 08-25-2013, 10:28 AM Thread Starter
KS_
Quoted: 22 Post(s)
It almost just seems to be that it didn't click until you push in the pedal about a half inch. When I look under and push with my hand it doesn't hit that little wire looking piece until that half inch
KS_ is offline
post #6 of 6 Old 08-25-2013, 02:24 PM
Quoted: 8 Post(s)
On mine, the IVS "button" is in contact with the metal tab off the pedal arm at idle. I actually hear the click at roughly the "1/2 inch" depression point. I would use a meter to make sure it is open at idle and actually closes. The TPS resistances should change smoothly when the pedal is depressed as well. Cheers!
