threw some codes! help! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-11-2013, 12:28 AM Thread Starter
NorcalPSD925's Avatar
well, on the way home a iroc did a ricer flyby up to the light so i line up with him and race and CEL came on in 3rd so i scanned it when i got home and this is what i got.
P0238 turbo boost sensor a circuit high input
P1211 injector control pressure higher/lower than desired
what can i do to prevent these?
truck runs hard till top of 2nd/beginning of 3rd till cel comes up, then doesnt pull as hard, is that because its defueling?
would a aftermarket HPOP prevent p1211? so its able to keep up with my demands?
truck is a 96 auto, 130cc ab splits, intake, exhaust and ts chip with php tunes (80hp performance)
might be off topic, but when i got my chip reburned from kt performance, i had it tuned for a 96 cali truck at first, but didnt start so i told him my PCM code and he said its non cali? and it runs with non cali tuning? pcm code is MIF4, which says online that is a 1996 auto cali pcm.
96 7.3L, RCSB, Race truck
Only regular cab short bed OBS in Nor Cal!
NorcalPSD925 is offline
post #2 of 5 Old 08-11-2013, 06:04 AM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
Hopefully someone with more real world experience will chime in, but I'll guess an upgrade on the HPOP and a "boost fooler" will help with those. Cheers!
Patrick Feeley is offline
post #3 of 5 Old 08-30-2013, 02:36 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 49 Post(s)
Cali Splits sometimes do need a boost fooler to get around the P0238, mine used to need it. This is a Cali. Splits model and as much as I hate to say it but Beans, IMHO, is the best tuner for Cali Trucks.
I'm with Patrick on that swapping in a SD HPOP will help with your ICP demands. DO you know your IPR duty cycle when you get the CEL?
EDIT: Sorry I didn't realize how old this thread was when I added to it.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #4 of 5 Old 09-01-2013, 07:47 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
Bump
I put Driven Diesel Boost Annihilator in and could still set a over boost code(I think IIRC I turned the knob)
So I bought Diesel site's boost relieve valve, and I still set a over boost code. What gives?
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #5 of 5 Old 09-01-2013, 08:36 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 49 Post(s)
^ your truck is too bad azz. It doesn't do anything small. Overboard on everything.
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
