Front Fuel tank sending unit, Where do you get one? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-06-2013, 06:55 PM Thread Starter
jimhuntertx's Avatar
Quoted: 3 Post(s)
Send a message via Skype™ to jimhuntertx
Question Front Fuel tank sending unit, Where do you get one?
I have a inop front tank sending unit and I have searched high and low for a replacement and all I can find is a gas motor sending unit? Will they work in a diesel tank? Please help? Is there a simple fix to this as it won't read above a 1/8 of a tank
Jim
97 F-250 2wd Extended Cab Longbox, Pyro,boost and trans temp guage, 3" down pipe,
New E4OD Trans, TS 6 chip
Banks TransComander, 4" to dual 4" Bullydog 4" Dual Exahust , DIY Tymar intake w/ K&N Filter, Shimmed FPR
jimhuntertx is offline
post #2 of 3 Old 08-07-2013, 06:27 PM
dirtcrew51m's Avatar
Quoted: 6 Post(s)
Believe it or not the old one can be fixed, assuming it is not cracked or brittle, pull it out, it can easily disassembled, when it is apart, take a pencil eraser, rub both contacting parts with the eraser, slightly bend the contact arm inward so it makes better contact with the resistor board, reassemble, you should now feel more resistance with the sender, take an ohm meter to test it. I have done this on a bunch of trucks and they are still working. As for the senders itself, there should be no difference between gas and diesel. The only other thing is the float broke or dissolved, if that is the case, I used a float from a Holley carb and soldered it to the arm.
dirtcrew51m is offline
post #3 of 3 Old 08-07-2013, 09:22 PM Thread Starter
Quoted: 3 Post(s)
Thanks Ill try that on my next set of days off.
Jim
