Fuel leak - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-05-2013, 04:10 PM Thread Starter
stroke'n'drive's Avatar
Fuel leak
What is this?
It's cracked and leaking out the port where you check fuel pressure can't find the part anywhere
stroke'n'drive is offline
post #2 of 5 Old 08-05-2013, 07:47 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
The part bolted to the fuel bowl with the 10mm hex heads is the Fuel Pressure Regulator. The sensor that screws into it is the Fuel Restriction Sensor. Maybe someone on here has an FPR they could sell you. If you get one from Ford (expensive), it is usually cheaper to buy the entire fuel bowl assembly which will have the FPR and wiring harness as part of it. Cheers!
Patrick Feeley is offline
post #3 of 5 Old 08-08-2013, 01:55 PM
Woodturner Nate's Avatar
Quoted: 2 Post(s)
I'll sell mine. I put new orings from diesel orings.com in it just before I did my efuel conversion.
2007 F350 King Ranch CCLB 4x4
WVO conversion in planning
RIP 1996 F250 eclb, 4x4, 7.3L PS
Viair 444C/6g air tank on frame, Hadley air horn, Hella auxiliary reverse light, DIY WVO conversion; Efuel, dual FuelLab FPR's, 90g RDS tank, aluminum tube-in-heater hose, hotfox heated fuel pickup, copper coil-wrapped filter, 40-plate FPHE, auxiliary coolant pump, 2000lb winch-crane bolted to the frame. Ranch hand front bumper. Big winch.
Woodturner Nate is offline
post #4 of 5 Old 08-12-2013, 01:11 PM Thread Starter
how much do you want? I need it asap
post #5 of 5 Old 08-13-2013, 03:41 PM
Quoted: 2 Post(s)
PM sent--I want to sell it as a complete unit.
