turn signal trouble please read - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-27-2013, 07:44 PM Thread Starter
i recently bought my 3rd powerstroke diesel it is a 1997 f350 4x4 got it running in a couple hours replaced ipr and fired right up ran it for a few hundred miles and today decided it was time to give it some more tlc left turn signal was working in front but not at the rear. bulb was good ,but replaced anyway .followed wireing back to where it goes up into engine compartment no juice.... checked fuses interior and under the hood still nothing . i know some about electric but this kicked my rear for 8 hours any connections under the hood or dash you all know of i can check ? any help would be
appreciated......... i do love these trucks sold the last one when diesel hit 4 bucks but i missed the power and gas at 3.80 with no power to pull just was not the answer so i found this regular cab long bed for 1800.00 303,000 miles seems to run great so far thinking of switching to synthetic oil( all of it ) also but first i gotta be able to turn left thank ya
trailerpuller#3 is offline
post #2 of 9 Old 07-27-2013, 07:50 PM
SuperCrutyPS's Avatar
Quoted: 333 Post(s)
Garage
Do you have a meter or test light to see if the plug in back is actually getting power? Any corrosion in the socket itself?
Just some thoughts.
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #3 of 9 Old 07-27-2013, 08:02 PM Thread Starter
yes used test light all the way to the engine compartment ,no juice... used ohm meter to be certain i was on the same wire when i had made it to the engine compartment ( wire good to light from engine compartment )
post #4 of 9 Old 07-27-2013, 08:05 PM Thread Starter
corrosion yes was some... cleaned with battery cleaner and brush re assembled with deox or diolectric grease
post #5 of 9 Old 07-27-2013, 08:08 PM Thread Starter
i am just really am not sure were it goes when it hits engine compartment and hate to to cut up any of the harness guessing
post #6 of 9 Old 07-27-2013, 08:24 PM
Quoted: 333 Post(s)
Garage
Just another thought...
Does the brake light work?
Has it been like this since you got it or is it something new?
Have you looked for a Chilton or Haynes manual that may have a wiring diagram in it to make is easier to follow the wires?
My Truck Garage:
Tow Toy Garage :
post #7 of 9 Old 07-27-2013, 09:10 PM Thread Starter
brake light works ...i believe it has been like this since i got it ...i have the chiltons guess i need to study that diagram somemore .......thanks now where did i put that magnifing glass
post #8 of 9 Old 07-30-2013, 12:18 PM
StrokinNSmokin6.0's Avatar
Mine just went through this problem and sure enough it was a bad relay that finally quit and I lost both left and right turn signals last weekend. On the inside fuse panel ON THE BACK SIDE of it their is a circular relay that plugs into the top of the fuse panel. I swapped it out with one that was on the front of the fuse panel (thats for the hazard lights) to test the relay before I bought a new one and that was my problem. Its like a 556 relay or 552 or 522 you get the idea.
Not sure that is your problem but a new $5 relay fixed mine.
04 F350 With all the mods.
StrokinNSmokin6.0 is offline
post #9 of 9 Old 07-30-2013, 12:56 PM Thread Starter
tryied that already but thanks for the tip still working on it
