old, dry cable snapped - not sure what it is - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-27-2013, 04:27 PM Thread Starter
wildturkeypete's Avatar
I was doing some basic maintenance today and noticed a small cable had dried up and snapped. I have attached a diagram of under the hood in hopes I can this easier. I can take a photo of it if necessary.
It's the cylinder in the very top left. I can't find it labelled in anything so I'm unsure of what it is.
THANKS!
Pete
Name:	1997 F250 73L engine.jpg
Live Free or Die.
wildturkeypete is offline
post #2 of 6 Old 07-27-2013, 04:38 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Is it a white cable?, that cyl is part of the ac system if I'm understanding what your saying usually covered in condensation after running it
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 6 Old 07-27-2013, 05:14 PM Thread Starter
Yep! Actually I should say it looks more like a white hose.
Live Free or Die.
post #4 of 6 Old 08-16-2013, 12:18 PM
Rockdog97's Avatar
Mine is the same way.. looks like the white "tube" goes into a vacuum switch and then gets routed into the loom, but not sure what it is or how to fix it? I guess I could just join the two ends back together then put some heat shrink on it to fix it?
Randy Wheeler
1997 F350 4x4 Crew Cab PSD LB
Rockdog97 is offline
post #5 of 6 Old 08-18-2013, 10:05 PM
Quoted: 44 Post(s)
It's a vacuum hose for the HVAC. Heat shrink will fix it.
madpogue is offline
post #6 of 6 Old 08-19-2013, 06:06 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
It closes the hvac system to use inside air instead of outside air when using max a/c
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
