Truck wouldnt start!!! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-24-2013, 06:36 AM Thread Starter
Skaggzy's Avatar
I went to start my truck this morning and it let me down. It turns over just fine but never fires up. The wait to start light stays on instead of going out after a few seconds like usual. There is also a weird electrical hum coming from the front. It drove just fine yesterday and the day before it pulled a Cam Position Sensor code and an exhaust sensor code. I will post the codes when i find where i wrote them down.
When i try to start it, the relay switch to the IDM is clicking. The wait to start light doesnt shut off. when i try to connect my code reader it comes up with an error that says it cant connect to the
1997 F350 4x4 CCLB
7.3L Powerstroke
S&B high flow intake, 3" DP to 4" straight pipe, TS 6-position switch, Transmission Temp Gauge, Superlift traction bars, 315/75R16 Falkin Rocky Mountains, Leveling Kit, E-locker in rear
Skaggzy is offline
post #2 of 5 Old 07-26-2013, 05:06 PM
USAF-FD-NJ's Avatar
Sounds like a dead high pressure oil pump
USAF-FD-NJ is offline
post #3 of 5 Old 07-29-2013, 04:36 AM Thread Starter
Skaggzy's Avatar
I think I've narrowed it down to a bad PCM. Once I replace that I will see if there are any other problems that I need to deal with. Does anyone know where to get PCM's other than a junkyard?
1997 F350 4x4 CCLB
7.3L Powerstroke
Skaggzy is offline
post #4 of 5 Old 07-30-2013, 05:33 AM
Quoted: 50 Post(s)
Have you load tested the batteries?
madpogue is offline
post #5 of 5 Old 07-30-2013, 06:00 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Read these two threads i made about my no-start situation. I was to the point i thought my truck was cursed but it ended up being i think the connector on the pcm was loose
I feel like I own a 6.0...
E-fuel for a dummy
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
