Steering Wheel Electrics - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-18-2013, 04:01 AM Thread Starter
I'm sorry, I posted this thread in the wrong forum and can not figure out how to delete.
I have a 96 350 Van w/ a 7.3. The horn and Cruise Control do not work, and the Air Bag warning light blinks. All the appropriate fuses that I could find have continuity. Where else should I look?
Thanks in advance.
Dick
tartansailor is offline
post #2 of 9 Old 07-30-2013, 09:27 PM
sgt dave's Avatar
Quoted: 3 Post(s)
did you ever get this figured out? i am having the same problem in my other truck, 96 cclb.
1996 F250 SC/LB, 4x4 PSD, ATS stage 1 trans 5 star tcc, AC codes,TW tunes, magnaflow 4" exhaust, 6637 , FS 2500 bypass oil filter,pure power reusable oil filter, isspro gauges, dieselsite cpr fuel pump system, adrenaline hpop, pml rear diff cover ,ebpv delete,non epbv pedestal, king pin dana 60, swamps idm, tru cool 4739
USMC 1993-1998
Plumbers & Pipefitters L.U.447
sgt dave is offline
post #3 of 9 Old 07-31-2013, 12:50 AM Thread Starter
post #4 of 9 Old 07-31-2013, 06:37 AM
sgt dave's Avatar
Quoted: 3 Post(s)
thanks for the reply. ill check it out. how did your van run before you fixed the problem?
USMC 1993-1998
sgt dave is offline
post #5 of 9 Old 07-31-2013, 07:32 AM
sgt dave's Avatar
Quoted: 3 Post(s)
my truck is running like im playing with the cruise control while im driving. hopefully the clock spring is the problem
USMC 1993-1998
sgt dave is offline
post #6 of 9 Old 07-31-2013, 08:38 AM
Quoted: 50 Post(s)
The trucks don't have what's nowadays called a "clockspring". It's just a set of concentric contact rings, IIRC they're built into the column. In any event, it's def. going to be different from the vans, since they have an air bag.
Sgt. Dave, is your truck speeding up with the cruise control, or just disengaging and then re-engaging?
madpogue is offline
post #7 of 9 Old 07-31-2013, 11:10 AM
sgt dave's Avatar
Quoted: 3 Post(s)
the cruise control buttons on the steering wheel and the horn dont work. while im driving it feels like the cruise is ingaging then disingaging. makes for a jerky ride.
USMC 1993-1998
sgt dave is offline
post #8 of 9 Old 07-31-2013, 11:12 AM
sgt dave's Avatar
Quoted: 3 Post(s)
ive checked all the fuses and relays and they are good, so im thinking its in the steering wheel fontrols somewhere.
USMC 1993-1998
sgt dave is offline
post #9 of 9 Old 08-01-2013, 10:03 AM
sgt dave's Avatar
Quoted: 3 Post(s)
any ideas anyone?
i took the truck to the dealer this morning. im in redmond oregon, 500 miles away from home so maybe they can figure it out.
USMC 1993-1998
sgt dave is offline
