95' E350 7.3 Ambulance - Ford Powerstroke Diesel Forum
post #1 of 13 Old 07-15-2013, 09:31 AM Thread Starter
I am new to diesel engines and just got this van. only 92K , but had sat for some 5 years I think. I believe the batteries and fuel pump are new.
It started right up every time, and ran great. I noticed the alt gauge was getting up pretty high. (Leece Neville*) I replaced the regulator and checked the brushes. it seemed to work, but was not putting out enough. I drove it on a long'ish trip and it ran fine and started fine.
I let it sit a day, and tried to start it and the batteries were dead (low, still a slow crank). I charged them up and still won't start. It turns over good, the warm light comes on, I replaced the glow plugs and checked the gp relay.
I let the batteries really charge up and even tried a jump. It really wants to but doesn't want to "catch"?
There is some white smoke when it tries, and to my nose I smell a heavy "electric" smell?
Thanks so much for any advice.
ThinkingWink is offline
post #2 of 13 Old 07-15-2013, 05:41 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Tried swapping the cam position sensor?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 13 Old 07-15-2013, 06:04 PM Thread Starter
CPS..
I have not tried the CPS. I have seen it a lot on forums, and called the Ford dealer for the OEM part (many say only get ford part?).
The guy on the phone said that probably was not it, when I told him about the situation. It's only 30$ and 2 bolts. Worth the try? I will try it in the morning, thanks.
post #4 of 13 Old 07-15-2013, 06:35 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
It's one bolt and a simple plug, cheap and easy, btw does the tach move while cranking?
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 13 Old 07-15-2013, 06:46 PM Thread Starter
This may sound pretty dumb, but either I don't have, or don't know what a "tach" is? O.o
post #6 of 13 Old 07-15-2013, 06:48 PM Thread Starter
Tachometer, RPM? I don't have one..
post #7 of 13 Old 07-15-2013, 06:51 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Ahh, forgot vans don't have those
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #8 of 13 Old 07-15-2013, 06:59 PM Thread Starter
Could the high volt during the small time with the regulator problem have caused a problem that wouldn't manifest until several hundred miles later? I would imagine that a short or overcharge would happen immediate? Would the start issue be related to changing the regulator and/or still having charging issues? Like could something go out from batteries dying?
Or am I looking at two different issues.
About the regulator. Why would I be only getting just over 12 coming out instead of 13-15? Did they give me the wrong reg? The old one had an adjustment screw, but not the new one. could the reg ruin the alternator completely? Crooked brush-re-install maybe?
You're awesome for your time! Thanks!
post #9 of 13 Old 07-15-2013, 07:19 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Sorry not sure on alternator and regulator issues, but since you have white smoke while cranking seems like idm and fueling issues would be ruled out, are all fuses good like the fuel bowl heater and what not, sometimes with the age of these rigs random things happen, but more often then not the cps does this
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #10 of 13 Old 07-16-2013, 07:05 AM Thread Starter
Okay. Swapped the CPS. Still nothing. cranks hard, wait light on, tries to, wants to, pops a few times but won't 'grab'.
I do not hear the fuel pump "buzz" like it's coming on. It it obvious? Could I hear it from the inside of the van over the start beeping, because I don't hear it. I checked the fuses, they are all good. i tried to look up the diagram , but from what i have found the "H" slot is for the fuel pump, but it didn't have one. I put another 30 in that slot, still nothing.
