Cylinder #6 has NO compression...... Its time for a a complete build.....
Any suggestions? |
man anthony! sorry to hear this! What ever you do build her strong as a ox!
Dang man, what happened?
I dont even know for sure yet. I have no compression on 6, Its time for a build now. Just need some help figuring out what parts to use.
Man sorry to hear about your luck, I was just telling my G/F bout your truck today because she calls mine high miles at 219k. Good luck with it.
Bump to the top....
Sorry to hear bout the truck Good Luck on the rebuild! ! !
What happened in order for you to end up doing a compression test? Was your truck running like a bag of azz?
It was running like chit, Did 8 contribution tests and cyl # 6 failed everytime and cyl# 1 faile 4 times. I pulled the injectors thinking that they were the problem. WRONG! The injectors were fine. I did not do a compression test. I went to purge the 2 cylinders, Sprayed oil and fuel like craxy out of #1 and NOTHING from #6. I stuck my finger over the glowplug hole on six and had my buddy crank it over, It wont even blow my finger off of the hole.......
joining to watch!!!
