aux light problem - Ford Powerstroke Diesel Forum
post #1 of 10 Old 07-03-2013, 05:04 PM Thread Starter
aux light problem
I recently put cab lights on my '94 F-350 and just wired them to the auxuillary lights instead of wiring them to a switch. Anyways not that light is out when i try and turn on the auxilary lights but the bulb is good cause it works when i turn on the blinker.. I'm stumped.
Thanks
oilburner23 is offline
post #2 of 10 Old 07-08-2013, 05:06 AM
Quoted: 50 Post(s)
What do you mean by "auxiliary" lights? What would the turn signals have to do with the cab lights?
madpogue is offline
post #3 of 10 Old 07-08-2013, 09:35 AM Thread Starter
I wired the cab lights to the right turn signal lights but when I turn on the head lights it won't light up
post #4 of 10 Old 07-08-2013, 09:59 AM
Quoted: 50 Post(s)
You need to wire them into the parking light circuit. If you wire it into the right turn signal, then they'd only come on with the right turn signal....
madpogue is offline
post #5 of 10 Old 07-08-2013, 10:22 AM Thread Starter
No that's what I did. And now it only lights up when the turn signal is on. When I turn the head lights are on it won't light up
post #6 of 10 Old 07-08-2013, 10:28 AM
Quoted: 50 Post(s)
So do you have it wired to the turn signal, or to the parking lights? It's not very clear.
madpogue is offline
post #7 of 10 Old 07-08-2013, 10:30 AM Thread Starter
Parking lights sorry
post #8 of 10 Old 07-08-2013, 01:19 PM
Quoted: 50 Post(s)
What color was the wire you tapped into, and where was it located?
madpogue is offline
post #9 of 10 Old 07-11-2013, 07:38 PM Thread Starter
The wire I tapped into that feeds into the orange parking light underneath the headlight is brown
post #10 of 10 Old 08-01-2013, 08:39 AM
gabegoforth's Avatar
Get out your test light and find a wire that is hot when the switch is pulled out. Really the way you should be trying to find the right wire. Make sure the wire doesn't become cold when other switches are turned. Ex dimmer.
1996 F-350 Crew Cab 4x4, Auto, Toyo MT 315/65/16r, full force 160/30% injectors, Super Duty electric fuel system, RiffRaff regulated return, Driven diesel electric fuel pump controller, SWAMPS HVHF IDM, custom tuned TS chip, 1.0 Turbo, CX Intercooler, 4" Exhaust, 6637 Intake, 4.10 Gears, 225k+ miles.
gabegoforth is offline
