7.3 Lopeing Idle warm or cold - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-30-2013, 08:57 PM Thread Starter
Hey guys. Just picked up a 95 Automatic Powerstroke. Clean rust free Southern truck with 195000 miles on it. Brand new E4OD Trans with 12000 mile warrenty. The issue is when i start the motor warm or cold the motor will lope for 3-5 seconds. after this it will smooth out but the engine feels like it has a slight miss. not bad. but enough to shake the cab. anything above idle runs great with no surging, missing, or anything else. the truck actually feels like it has more power than it should. things that have been checked are injector buzz test passed, Contribution test passed with flying colors, No codes or CEL's. I tried starting the truck with the ICP disconnected and it still does it. I tried starting in Neutral to rule out the transmission range selector and it still does it. The truck and motor are very clean and were previously owned by a very respectable Diesel shop here in town. They tell me that some motors do it. some dont. its just something to live with. im not sure i believe this and would like to fix it if at all possible. does anybody have any ideas??? Engine Oil has 1000 miles on it and is 15-40w. Not sure what else to check and have limited diagnostics tools on hand. i am technically inclined and used to own a 6.0 and was balls deep many times in it. any ideas would be great. It Does the EXACT same thing as the video below.
2003 F350 XLT with a 6.0 PSD
Viper 5701
SCT with Innovative Tunes
(Tow, Tow/Brake, Aggressive Street, Extreme Street, Extreme Race)
4" Turbo Back Straight Pipe
Sinister Diesel EGR Delete
Autometer Z-Series Pyro, Boost, and Trans Temp
S&B Intake
08+ Rear Conversion PTM
05+ conversion PTM with Hellas Frenched in Bumper
Factory Fender Flares
5k HIDs
Reflexxion Cowl Hood
Maxx Lift 2.5" Leveling kit
22" Hulks with 37" Toyo M/T's
2-12's and 1100 watts RMS
Wojo is offline
post #2 of 10 Old 07-01-2013, 09:16 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 44 Post(s)
Normal for me. It's most likely your glow plug system (watch the video and see that on the alt/batt gauge as you cycled the key the Batt showed one level that almost immediately the gauge reads lower. This is the GP relay turning on). On startup whether hot or cold your truck will fire the glow plugs for a test for a couple seconds. This test is really hard on the batteries and alternator and as such boggs the engine down a little bit. By watching your Alt. gauge during the video you might want to have your batteries and the alternator checked now anyway. The needle didn't go up at the end of the GP test as much as I like to see.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 10 Old 07-01-2013, 09:31 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Mine does that too, im gonna pick up some new batteries tonight and see if that helps at all. Otherwise id say its pretty normal for an 18 year old truck.
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #4 of 10 Old 07-01-2013, 12:50 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
I can't remember if there are any folks left on here that had one of the TEE5 programs in their 95 PSDs. I'm not sure if these had the lope or not (I know that's very helpful). They tended to have what seemed like good power, so much so that Ford started repregramming them when the trucks were brought in for service (unbeknownst to the owners!). The guess at the time was to avoid having transmission issues. Of course the owners weren't real happy with the resulting (what seemed like it anyway) performance loss. Do you know what PCM code you are running? Any of you old-timers out there care to comment? Cheers!
Patrick Feeley is offline
post #5 of 10 Old 07-01-2013, 08:03 PM Thread Starter
Its not the Batteries. everything runs good. The lope at startup doesnt bug me one bit. but the lopey idle is irritating and shakes the whole cab including me. it defineatly FEELS like an injector is out. One new detail that started tonight tho is i started the truck up and let it idle for 15 minutes while i bull****ed with some coworkers after work. temp outside was 90 degrees. no smoke on startup. no smoke at idle. when i went to leave i pulled on to the road and gave it a small amount of throttle and it smoked white for about 100 feet and then quit. i tried replicating it with some full throttle runs and got nothing. im now wondering if it IS in fact an injector. or if the UVCH's can cause an injector to smoke. not sure what it was. first time its done it.
Viper 5701
S&B Intake
5k HIDs
Wojo is offline
post #6 of 10 Old 07-01-2013, 08:53 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 44 Post(s)
How "just picked up" the truck? Didn't you have torrential rain there last week or was that a little more south of you?
Matt
'97
-Stage II trans.
BigFuel is offline
post #7 of 10 Old 07-01-2013, 09:43 PM Thread Starter
Bought the truck recently. last week as a matter of fact. and no. it was more east of me. we got a lil bit. but not a ton. and i bought the truck AFTER the rain. it wasnt driven through the rain storm
Viper 5701
S&B Intake
5k HIDs
Wojo is offline
post #8 of 10 Old 07-01-2013, 10:11 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 44 Post(s)
K. The IDMs in our truck where sealed 15-18 years ago. By now the seal is probably shot and water can build up in it causing all kinds of issues including stutters to completely frying the IDM. Another thought is to pull the Garrett fix and order a IPR rebuild kit. If its never been cleaned then its due. Also pull the FPR apart and clean it out. Can be gummed up too keeping fuel pressure from where it needs to be.
Matt
'97
-Stage II trans.
BigFuel is offline
post #9 of 10 Old 10-16-2013, 04:12 PM
I'm having the same exact issue with the lope start and shake at idle. also having a shake/miss feeling at 1100rpm and 1600rpm in park. I've checked everything without any luck.
tony0713 is offline
post #10 of 10 Old 10-16-2013, 04:47 PM
luke7.3's Avatar
Quoted: 24 Post(s)
Mine does it too. It might be something the 7.3 eventually gets and you'll just have to live with it
Luke
97 F250 CCSB 4 inch straight pipe, 6637 intake, TS 6 pos (daily)
08 F350 6.4 Reg Cab flatbed Spartan tuned, AFE Intake, DPF/DOC Delete(work truck)
luke7.3 is offline
