need some brake help - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-24-2013, 06:23 PM Thread Starter
EflumE's Avatar
Quoted: 30 Post(s)
i blew a brake line out so i replaced all the lines. when i went to bleed them the bleed valves on the rear were so rusted that i couldn't get them open. sprayed them with penetrating oil for three days. needless to say i broke the valve off the threads.
i bought new wheel cylinders. that is the only way i can fix the issue.
does anyone have tips or tricks you'd like to share on getting the drums off?
is there anything else i should do while i'm in there?
is it as simple as tires off, drums off, replace wheel cylinders, put everything back together?
thanks guys...
-Eric-
96 cclb, baby swamps, TS 6 position w/swamp's tunes, billet wheel, 1.0 housing, diy ebpv delete w/plugged pedestal, 3" downpipe to 4" exhaust, 6637, boost, egt, trans gauge, fully built trans, 203* tstat, 08 diff cover, airlift helper springs
218,000
9 inch skyjacker on 37" interco M16's
EflumE is offline
post #2 of 4 Old 06-24-2013, 07:18 PM
Chop's Avatar
Drums can get a little sticky after awhile ,they tend to attach themselves to the axle stub by corrosion . A good whack on the circumference of the drum with a large hammer will generally break it loose .If not then back off of the adjusters ,you'll need to do that anyway
1996 F250 PSD Crewcab,auto,D 60 swap,3" dp, DIY air 4X4 Centurion
Chop is offline
post #3 of 4 Old 06-25-2013, 03:03 PM
Quoted: 48 Post(s)
^^^^^ Note on the above - the drum can act like a bell, that is, when you whack it, it can make a VERY loud "clang". If you have to hit it several times, hearing protection may be advised. And don't do it around neighbors who have a bug up their @$$ about noise....
madpogue is offline
post #4 of 4 Old 06-25-2013, 04:22 PM Thread Starter
EflumE's Avatar
Quoted: 30 Post(s)
haha...
thanks guys i'm getting on it tomorrow. luckily i don't have any of those type of neighbors you speak of
-Eric-
218,000
EflumE is offline
