Short? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-28-2008, 01:29 PM Thread Starter
Short?
Well my drivers side tail lght is out. Replaced the bulb, nothing. Any ideas what to check? the drivers side liscense plate light is also out, the whole setup is melted, Any ideas will help ALOT!!! Btw its a 1995 f250 powerstroke! Thanks!!!!!
hunter is offline
post #2 of 2 Old 03-28-2008, 01:32 PM
Desert Shield/Storm Vet
vitalidle's Avatar
No probobly not a short as the fuse would have blown. You may have some corrosion and some resistence in the wireing and it got hot.
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
