Exterior locks dont unlock with key - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-17-2013, 05:35 AM Thread Starter
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
I guess my outdoor locks dont work on either side of my OBS. And i found out the hard way is this a common problem and a linkage just falls out because it feels like it wants to unlock but just wont or is the lock itself broke?
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #2 of 7 Old 06-17-2013, 06:01 AM
mkeith54's Avatar
Pat,
I live on a gravel road and the locks got so gunked up they would not work like yours are. I have a cheap harbor freight ultrasonic cleaner and two trips trough it with hot Simple Green and they work fine now. Don't use an oil that stays around as it will attract more dust. Some people suggest Graphite, However the Military had us quit using it because it would gall up the metal.
Mike Keith
New Florence Mo
1996 F-250 ECSB, 6-pos/ts chip/ Tymar intake
Pyro, boost, and tranny gauges
mkeith54 is offline
post #3 of 7 Old 06-17-2013, 06:16 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Well its not like its gunked up or anything. You can put the key in and turn it just like normal the lock just doesnt engage anything, the little part that pops up doesnt even budge when i do it so im thinking the linkage from the lock cylinder to the actual door lock is broke or something so as soon as i can get it open ill pull the door panel and look inside
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #4 of 7 Old 06-17-2013, 06:31 AM
mkeith54's Avatar
On the back inside of the door there is a zinc colored clip that hold the lock in, popit out and see it the link is still attached the metal spring clip that holds the rod in place may have failed.
Mike Keith
New Florence Mo
mkeith54 is offline
post #5 of 7 Old 06-17-2013, 06:34 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Thanks man ill check that out tonight
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #6 of 7 Old 06-17-2013, 07:31 AM
Turbostang500's Avatar
Not 100% sure but I thought OBS had little plastic clips that hold the linkages together and they get brittle and crack. Either way, your pulling the inner door panels.
Lee
2000 F250 PSD SCSB 4X4 418k miles straight pipe gauges 2" leveling kit 315/75r16's
6637 with custom intake pipe. TS Performance 6 position chip!
[/URL]
Please don't confuse my attitude with my personality.. my personality is who I am,my attitude depends on who you are...
Turbostang500 is offline
post #7 of 7 Old 06-18-2013, 06:36 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Your exactly right i pulled the door panels last night and found the little plastic piece that wraps around the lock and pulls the actuator up and down when you turn the key, Then i pulled the lock out and super glued the pi$$ out of it(making sure not to get it in the lock itself obviously) then let it dry then coated it in clear silicone glue just for that added hold. Now they work great and no getting locked out
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
