Speedometer jumping - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-16-2013, 08:50 PM Thread Starter
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Speedometer jumping
I just picked up a 95 7.3 and am starting to fix all the little things and one is the speedometer jumps at high speeds thus screwing with the cruise, My 95 Bronco did the same thing and reading some threads others have the same problem. Im new to the OBS so please if someone could explain how to fix this please
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #2 of 10 Old 06-18-2013, 06:50 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Bump anyone?
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #3 of 10 Old 06-18-2013, 08:45 AM
Quoted: 53 Post(s)
VSS - vehicle speed sensor - in the rear diff is the prime suspect. May also be the wiring to it, or the tone ring on the diff that it interfaces with. Any idea how old the diff fluid is?
madpogue is offline
post #4 of 10 Old 06-18-2013, 08:53 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
probably about as old as the truck. Im in the process of changing all the fluids. When im in there ill replace the vss and take a look at the wiring and tone ring(thats just a small gear that engages the differential gears right?)
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #5 of 10 Old 06-18-2013, 10:18 AM
Woodturner Nate's Avatar
Quoted: 2 Post(s)
And when the vehicle speed sensor doesn't work, you will end up with a new speedometer/odometer like I did. My problem was intermittent, and I thought the VSS fixed it, at least for a couple hours. The speedometer needle is powered by a little motor. On my truck, there must have been a short somewhere, because it worked a few times to smack the dash. It only worked a few times. You can go to a junkyard and pull one out fairly easily, lots of screws and three harnesses to disconnect on the gauge cluster, but easy enough to do. Go slow or you'll break the clear cover like I did. DOH!
2007 F350 King Ranch CCLB 4x4
WVO conversion in planning
RIP 1996 F250 eclb, 4x4, 7.3L PS
Viair 444C/6g air tank on frame, Hadley air horn, Hella auxiliary reverse light, DIY WVO conversion; Efuel, dual FuelLab FPR's, 90g RDS tank, aluminum tube-in-heater hose, hotfox heated fuel pickup, copper coil-wrapped filter, 40-plate FPHE, auxiliary coolant pump, 2000lb winch-crane bolted to the frame. Ranch hand front bumper. Big winch.
Woodturner Nate is offline
post #6 of 10 Old 06-18-2013, 10:37 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Well maybe ill do that first to see if that alleviates my problems since ill be at the junkyard probably next weekend.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #7 of 10 Old 06-18-2013, 10:45 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Easiest way that fixes most is just pull the plug off the top of the rear clean it and check, then while your changing the diff fluid inspect the tone ring if your problem persists, then go into the harder stuff listed
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #8 of 10 Old 06-18-2013, 10:53 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Sounds good will do I should just PM you about my problems instead of mucking up the threads
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #9 of 10 Old 06-18-2013, 02:00 PM
JSchuricht's Avatar
The way the system works is there is a tone ring attached to the carrier in the rear, the VSS counts the teeth and sends a square wave signal to the front. The wire is split to the PSOM and RABS. The PSOM converts the signal to sign wave and sends it to your PCM which controls the trans if you have a auto.
The VSS is the most common cause however the PSOM is a close second. The good thing about the PSOM is you can get one from any F-150, F-250, F-350 or Bronco from a similar year and just swap that section of the cluster. If you have access to a oscilloscope, you can watch the signal and see where the issue is. In my case it ended up being the RABS unit which I just left unplugged.
JSchuricht is offline
post #10 of 10 Old 09-17-2013, 06:28 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Well about 3 months later i finally got around to doing this and surprisingly it was actually my problem. The speedometer works great now. Still has a slight twitch at high speeds but not like going up and down 10mph at every bump so i will worry about the tone ring when i change diff fluid
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
