Frankensteins alternator - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-16-2013, 09:21 AM Thread Starter
Blazin8556's Avatar
Went to the store a while ago, on the way home I started hearing some squeaking from the belt driven stuff,(super technical). Got home popped off the belt seems its the alt, and/or the pulley to the right of the alternator. I have 2 other alternators laying around in addition to the one on my truck.
I have an explorer alternator rated at 95 amps, same mounting setup wrong pulley and too low amperage.
I have a 92 fox body alternator, 200 amp, wrong mounts and pulley
And the alternator on my truck. Possible bearing issue, 130 amps right pulley(obviously),
Anyone see where I'm going with this?
I see an upgrade opportunity, what I'm thinking is changing the front of the fb alt with the one from the ex and throwing my pulley on there. What do you guys think. I don't really want to spend the $150 on a new alt when I have this stuff laying around. All cases are the same except the fronts that have the mounts all three have the same regulator wire layout as well.
1995 F350 XLT|DRW|7.3L Powerstroke|1.0 turbo|3" Diamond Eye Downpipe|Straight Piped|EBPV delete|DIY 6637|RiffRaff turbo inlet boot|203* thermostat|IDM mod|CCV|Built E4OD|Derale Trans Pan|Trans Temp Gauge|Explorer RAP RKE. Traded for a chevy
2007 F350 Lariat 6.0 . under the knife already
Blazin8556 is offline
post #2 of 4 Old 06-17-2013, 07:46 AM Thread Starter
Blazin8556's Avatar
Did some more looking, found out what all I need to do and found the part number on the mustang alt. it's not a 200 like I thought its a 130. Not sure where I got 200 from.
post #3 of 4 Old 06-17-2013, 07:54 AM
ZMANN's Avatar
Quoted: 1560 Post(s)
alternator parts.com can sell u the bearing FYI or even upgrade parts
We Miss you Ronnie
ZMANN is online now
post #4 of 4 Old 06-20-2013, 11:34 AM
Quoted: 2 Post(s)
are u sure the exporler one is 95 amps ive got a 94 model exporler one on mine and it was listed at 130 amp just swapped the pulley and no charging problems since
97 f250 4x4 ccsb
auto
typical exhaust /6637 intake/ chip
add a leaf leveling front
otherwise mostly stock
joshh77 is offline
