Fuel lines - Ford Powerstroke Diesel Forum
post #1 of 2 Old 06-08-2013, 12:19 PM Thread Starter
dirtcrew51m's Avatar
Quoted: 6 Post(s)
Fuel lines
95 F250 7.3 turbo. The steel fuel lines running from the flex lines by the steering box up to the filter and other by the turbo, looks like a 5\16 and a 3\8 line, are rotted and are leaking, can I bend up new lines and re-route them instead of putting them in the original spot? Also, the metal line is connected to the regulator with a rubber hose and clamps, can I do the same by connecting the new lines up top and from the factory lines below? I can also get the fuel injection repair ends and make up the hoses. If it can be done I will use fuel injection hose for the repair.
dirtcrew51m is offline
post #2 of 2 Old 06-11-2013, 05:32 PM Thread Starter
Quoted: 6 Post(s)
It was the steel return line at flex hose, removed and re-routed new line with steel, joined new line to factory steel line with a piece of FI hose, works great. When more funding comes my way, I am planning to replace both with Aeroquip braided stainless line.
