oil psi help - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-05-2013, 04:36 PM Thread Starter
kkbodyshop's Avatar
oil psi help
truck has 217k miles an runs great after i had everything fixed on it lol. noticed today that my oil psi guage is reading on the n of normal. checked the oil an it was a quart low so i topped it off. i did put hot shot secret in it last oil change. its getting hot here in south carolina jus wondered if it normal an do you think it may be low psi cuz of the hot shot secert?
94.5 f350 dually
216k miles
straight piped
intake
fuel shim
ts chip
kkbodyshop is offline
post #2 of 3 Old 06-05-2013, 04:46 PM
jesilvas's Avatar
Quoted: 2 Post(s)
I'm wondering if the PSI is actually low or the gauge is just dumb.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 3 Old 06-05-2013, 05:57 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
Unless you've modded the gauge, the factory OP gauge is really only a glorified idiot light. The setup does not use a sending unit that varies resistance with temperature, it only uses a pressure switch that is either ON or OFF depending on the setpoint (6 psi I think). The gauge is supposed to read mid-scale above that pressure. That all said, the gauges are funky. My 94's would do the same thing as yours (and anything in between). If you pull the wire on the switch (top of the HPOP reservoir on passenger side) and ground it, the gauge should read mid-scale. If it doesn't, there is probably a problem with the gauge itself or the wiring to it. Cheers!
Patrick Feeley is offline
