pyro wont work??????? - Ford Powerstroke Diesel Forum
Old 03-15-2008, 09:02 AM
i have plummed and wired right. whats the deal??? and yes iv doubled checked it.
Old 03-15-2008, 09:05 AM
If it aint a CAT itsa DOG
How did you hook up the power to the gauge? What brand of gauge is it? I have isspros and my pyro wouldn't work because i had a wuick conncect with a bent tab that i didn't know about.
Old 03-15-2008, 09:51 AM
they are autometers and the probe and light wires were already wired into one plug that pluged into the guage??? could the gauge be bad???
Old 03-15-2008, 09:59 AM
could be. Can you put a test light on the power wire to make sure that the gauge is getting power?
Old 03-15-2008, 10:18 AM
i know its getting power cause it lights up.... or is that on a different wire???
Old 03-15-2008, 10:24 AM
Well on my isspro, i had to make my own separate wires for the back light. The power to the actual gauge was different. I had to tap into a wire under the dash to get power off the ignition. Heres a link to installing thes gauges. Check it out and maybe you can find wour problem. I'm not 100% sure how the auto meters are setup, but this might still help you.
DieselManor - Installation Sheets
Old 03-16-2008, 07:53 AM
dan, I put these gauges in for him. On the 12 V+ I had test light come on with key in "run" position, illumination wire was ran to the instrument panel fuse, and ground was obviously ran to a metal ground. The probe was a clamp type, the probe is in tight and the wires were already hooked to it when I got it..
We Used the same power, ill., and ground wires on all the gauges by tapping into them with the little blue taps to keep it as clean as possible, so we didn't have to run 20 wires into the kick panel.
Luke
Old 03-16-2008, 07:59 AM
Isn't there a tube for the vacuum to the guage? Mine has wires for the light and a hose that gets tapped into on the MAP sensor hose.
Old 03-16-2008, 08:01 AM
Never mind that last reply. I was thinking boost.
Where did you hook the temp sender into?
Old 03-16-2008, 08:28 AM
KVFD
red my pyro doesnt work too. i noticed when i installed the previous owner had power to both sides of the gauge so i dont know if its fried or what cuz it doesnt work either. so i would like to know to see if its fried
