stil no start - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-01-2013, 11:18 PM Thread Starter
ole96stroker's Avatar
Exclamation stil no start
Well guys my truck stil want start ive narrowed it down to my idm or fuel pump. The relay is kicking on for the idm though. Fuel is.coming out of the valve but not fast I thought ive read if not enough pressure it want fire, i did do the bb mod like a month ago and the truck started running bad so i took it out and ran like it should then a month later truck died wouldnt start back, cps is good hpop everything, could it be fuel pump?thanks
******1996 ford f250 powerstroke 5 spd 4x4******
***170,000 miles, ts 6 pos, intake, exhuast***
ole96stroker is offline
post #2 of 5 Old 06-02-2013, 07:47 AM
Patrick Feeley's Avatar
Quoted: 9 Post(s)
What is the fuel pressure when cranking (spec is 25 psi minimum at minimum crank speed of 100 rpm). Oil level OK? Wait-to-Start light illuminating? Cheers!
Patrick Feeley is offline
post #3 of 5 Old 06-02-2013, 11:49 AM Thread Starter
I put a gauge off a paint gun on it andbit takes a few seconds to start building but after cranking it pegs out 40 psi and just flutter's and yes wts is working and everything.thanks
post #4 of 5 Old 06-02-2013, 12:15 PM Thread Starter
and no smoke coming out of tailpipe while cranking
post #5 of 5 Old 06-10-2013, 07:23 AM
95strokerpaul's Avatar
sounds like the problem i'm having. So i'm subscribing! Good luck!!
HAVE:
2012 F350 cclb xlt larriet
-18" black fuel wheels -Black Fab Fours front bumper -custom painted black Protech tool box and cab guard -20 tinted windows -Recon on the mirriors and roof -bought: 4/27/12 @ 99 miles -currently at: 60k miles (I still got wood)
-S&B in -MBRP duals out -emissions = GONE!! -SCT tunes
Made 425/828 (uncorrected)
2008 HD street Bob, some go fast goddies 124hp 124 tq. RIP
95strokerpaul is offline
