Water in fuel light off and on - Ford Powerstroke Diesel Forum
post #1 of 2 Old 06-01-2013, 10:42 AM Thread Starter
I get the water in fuel light on every once in a while. Sometimes it comes in solid and sometimes it just flashes on and off. I drain the bowl and have never gotten any water. Should I get a new sensor or is there something out there that I can delete it with? Where do you recommend getting it from?
tucker0104 is offline
post #2 of 2 Old 06-01-2013, 09:01 PM
Patrick Feeley's Avatar
Quoted: 17 Post(s)
Inspect the wiring around the fuel bowl. Leaking diesel fuel can turn the wiring insulation to goo. You can get away with not having the fuel restriction sensor, but I would want to keep the Water-In-Fuel circuit fuctional. Look for the WIF switch (which is cube-shaped on the drive's side engine harness). Cheers!
Patrick Feeley is offline
