Fuel gauge problems - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-30-2013, 05:36 PM Thread Starter
Fuel gauge problems
Anyone else out there have fuel gauge problems? Somewhere on empty or over full all the time. Never knowing how much is in the tank. How do I diagnose and fix this? I am born with a horrible curse of not being able to just let things being broken. It sucks.
tucker0104 is offline
post #2 of 7 Old 05-30-2013, 06:26 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Tried fixing/replacing the floats in the tanks?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 7 Old 05-31-2013, 07:29 AM Thread Starter
Not yet. How do I get to them?
post #4 of 7 Old 05-31-2013, 08:00 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
Easiest way is to get some buddies and some beer and pull the bed off. Unless you have a Reese system it's only 4 bolts, 6 screws, some bands, and a little lifting. This way you can leave fuel in the tanks and not have to fight the weight and size of dropping the tanks. Get a new tank seal kit, don't reuse the old one.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #5 of 7 Old 05-15-2014, 03:09 PM
Dzldust's Avatar
I just put a brand new sender in my front tank and now it reads way over full,have no clue whats up.
Dzldust is offline
post #6 of 7 Old 05-15-2014, 03:55 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
The sending units are not "manhandle" calibrated. Bending the float rod is sometimes needed for proper readings on the gauge.
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
post #7 of 7 Old 05-15-2014, 04:01 PM
Dzldust's Avatar
after some research it would seem that most people feel that a gauge reading too high or maxed out indicates an "open" circuit and no reading at all is a ground issue....Most people are talking about their old sender acting up,my issue is with a brand new sender which the arm was identical to the one that was being replaced
Dzldust is offline
