loosing oil in 95 f250 7.3 liter turbo - Ford Powerstroke Diesel Forum
Old 03-12-2008, 10:32 AM
just bought this truck and it goes through a gallon of oil a day any suggestions or possible causes.there is no excessive smoke or can you see any signs of an oil leak
Old 03-13-2008, 11:06 AM
Gun Nut
Welcome to the ORG. Let me give this a bump for you to see if anyone has an answer.
Old 03-13-2008, 11:15 AM
a gallon a day? and no smoke or leaks man i dont know whats up with that, good luck, hope ya got a deal on the truck!! Welcome to the ORG
Old 03-13-2008, 12:09 PM
so your truck goes through 4 quarts a day if that is happening don't drive your truck don't want to hurt it anymore. take it back and get it fixed if possiable if you can't then the problem needs to be found. but if there is no leaks and nothing coming out of the exhaust. than I don't know where the oil is going.
Old 03-13-2008, 12:21 PM
MY 99.5 was doing the same thing, using a TON of oil with no leaks and no noticable/excessive smoke, i took it into the shop and it was pronounced dead. you probably are burning it...start it and take the oil cap off, see if it dont spray oil all over the place. you might be lookin at a rebuild. when i pulled my engine apart, 4 of the cylinders were full of engine oil/fuel.
Old 03-13-2008, 07:19 PM
stroker, it wasnt smokin blue at all before you tore it down?
Old 03-13-2008, 07:51 PM
If not oil Leak, ya gotta be burning it.
It has to go somewhere.
Sounds like time for a rebuild!
Old 03-14-2008, 06:21 AM
it was.... when i would get on it hard it would... but cruising you could hardly notice/see it.
Old 03-14-2008, 06:38 AM
when youd get on it was it very noticeable or not really bad, at night if someone is following my on a low setting and i get on it you can see some blue but not really any during the day
Old 03-14-2008, 07:37 AM
SOUNDS LIKE YOUR ENGINE IS TIRED,CHECK COMPRESSION
