Towed for the first time,have problem! ! ! HELP
well yesterday i towed for the first time with my 97 350 dually psd automatic. mind you it is all stock, and i was towing about 11k. It towed great all until i was about to merge onto the highway, and it has done this twice before on open roads. It seems like in third gear as i am under full load trying to merge, at about 2800 rpms or so the truck must like defuel or something, it slowly misses.. almost like a limiter or something..
any ideas on what it might be? if i let off and it shifts, it is fine but it is almost like it struggles to get to like 75mph.. any info would be great.. is the wastegeate spring weak? |
anyone here?
You aren't in OD right?
no sir why?
Well by no means am I tech, (had to premise with that), but I had a truck that did that and it was my TC. Hoping in your case it's something else!
Ck for codes. Poss. restricted filters(air&fuel). Poss. weak hpop. Or poss. trans converter problem.
ok will check the codes and filters first, but how would you check the hpop?
also under acceleration it sounds like i have an exhaust leak,
it like puffs air pfft pfft pfft pfft
