'95 F250 Shaky Speedo & ABS light - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-25-2013, 06:00 PM Thread Starter
Question '95 F250 Shaky Speedo & ABS light
It was very bad. Speedo wouldn't register under 30 and bounced around like a big dog while driving.
I pulled the diff cover, Oil was burnt and factory, of course. However, No metal shavings in oil. the tone ring was not missing teeth.
I put the cover back on, refilled, replaced the VSS. Used some electrical safe cleaner on connector.
This did offer quite a bit of improvement. It registers at low speeds and the swing is much less, but still there & the ABS light is still on.
Where to go from here? Replace the Harness?
Any help would be awesome.
- Joe
Built. Not Bought.
Irish95 is offline
post #2 of 7 Old 05-25-2013, 07:33 PM Thread Starter
Update!
ABS light is OFF! I disconnected ground to reset ECM. Going to put 120+ miles on it in the morning. Will post another update.
- Joe
Built. Not Bought.
Irish95 is offline
post #3 of 7 Old 05-26-2013, 05:02 PM Thread Starter
114 Miles, ABS light is still off. Speedo still shaky.
Built. Not Bought.
Irish95 is offline
post #4 of 7 Old 05-26-2013, 11:01 PM
JSchuricht's Avatar
There are only a few components in that loop. The tone ring could have teeth that are bent rather than missing. The VSS could be bad. The wire or connectors could be bad. PSOM could be bad or the RABS could be bad.
If you have access to a oscilloscope, you can jack the rear end up and connect to the VSS to check the signal. Otherwise you are just guessing. The VSS is only about $30 so I would start with that.
JSchuricht is offline
post #5 of 7 Old 05-27-2013, 03:35 PM Thread Starter
Question
Did the new VSS (18$, Ato Zn), Changed the harness also($11), tone Ring looked good.
165 miles since ABS light shut off. Has not come back on.
I am going to take it to electrical specialist friend of mine to look for short or pinch in line.
Built. Not Bought.
Irish95 is offline
post #6 of 7 Old 05-28-2014, 09:35 PM
I am experiencing the same problem. Did you ever find the solution to the problem?
acardiel11 is offline
post #7 of 7 Old 06-25-2014, 05:34 PM
nick40's Avatar
Send a message via MSN to nick40 Send a message via Yahoo to nick40
I have the same problem but mine only oscillates between 45 and 55 mph... Any updates?
96 F-250 2wd. SRW, CC, 176 K on tha clock
Performance:
4in. Flo-Pro exhaust, Tymar intake, AMSOIL synthetic motor oil, Fleetguard CC2820 coolant, HPX mod., Edge Evo., AC mod., CCV mod., FPR BB shim, EBPV gutted, Tymar coolant filter
Appearance:
33 in. Toyo Open Country A/T's., low profile Bullett toolbox, Herculiner bedliner, lockable rear bumper, diamond clear bumper, corner, and headlights, Ranchhand front bumper
nick40 is offline
