Can cps still show rpm if bad? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-21-2013, 10:47 AM Thread Starter
ole96stroker's Avatar
So my truck still isn't starting I have checked everything there is to check, my cps is still reading rpm but can it still be bad?? I baught one from advance and truck still didn't fire then someone told me never to use a cheap one so I took it back. thanks
******1996 ford f250 powerstroke 5 spd 4x4******
***170,000 miles, ts 6 pos, intake, exhuast***
ole96stroker is offline
post #2 of 5 Old 05-23-2013, 07:30 AM
EflumE's Avatar
Quoted: 31 Post(s)
yes it can. mine did.
there are a lot of guys on here that will probably tell you that the tach isn't really the most reliable way to know if your cps is bad.
What were the symptoms before the truck didn't start anymore?
look for a guy with an Autofair screen name. When mine went bad he replied to me, quoted me a great price for the ford piece and had it on my doorstep in two days.
-Eric-
96 cclb, baby swamps, TS 6 position w/swamp's tunes, billet wheel, 1.0 housing, diy ebpv delete w/plugged pedestal, 3" downpipe to 4" exhaust, 6637, boost, egt, trans gauge, fully built trans, 203* tstat, 08 diff cover, airlift helper springs
218,000
9 inch skyjacker on 37" interco M16's
EflumE is offline
post #3 of 5 Old 05-23-2013, 07:33 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
As said its possible to be bad and still show rpm, but mine is from autozone works fine
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 5 Old 05-23-2013, 07:58 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Yea they can be intermittent, thats what happened to mine, it would work fine sometimes and then others it would kill it at idle.
As for autofair he changed his name its now 2000-7.3L. His name is dylan, he has good prices(dont let him know i said that though)
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #5 of 5 Old 05-29-2013, 09:01 PM Thread Starter
Before the truck died and wouldn't start back it would act like it would want to take off while not even touching the pedal for some reason when letting the clutch out, and I found that my icp nut had fell off and it was just sitting there going all over the place.
