fender removal problem... I must be an idiot - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-18-2013, 06:32 AM Thread Starter
pittdiesel's Avatar
Hey guys
I have the awesome obs fender wheel well rust.
I have a new fender and I can't get the old one off. All bolts are off headlight out its just hanging but stuck around the front headlight where the two pegs are hooked on the fender. What am I missing? Anyone know a video? Thanks. Do I have to take the whole front end off meaning the black plastic/core support?
Sent from AutoGuide.com App
pittdiesel is offline
post #2 of 8 Old 05-18-2013, 01:59 PM
Chop's Avatar
Check the mounting holes on the replacement fender against the truck . You could be missing the hidden fastner
1996 F250 PSD Crewcab,auto,D 60 swap,3" dp, DIY air 4X4 Centurion
Chop is offline
post #3 of 8 Old 05-20-2013, 08:25 AM Thread Starter
pittdiesel's Avatar
Thanks I will do that.
post #4 of 8 Old 05-20-2013, 08:30 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
There is a bolt in the crack where the door and fender meet! Did you pull those?
2000-7.3L is offline
post #5 of 8 Old 05-20-2013, 08:44 AM Thread Starter
pittdiesel's Avatar
Yes got those. Everything from the rear to front good. I can pull fender completely out, I just can't get it unhooked from the front begone the headlight housing. It's stuck there. The red pins and black housing and the black plastic starlike snap.
Your suppossed to push it forward and kind of swing it out I think. It's just hooked in. And can't get it far enough without worrying about breaking something plastic on headlight stuff.
Driving me nuts. Maybe a second look will help.
post #6 of 8 Old 05-20-2013, 08:51 AM
2000-7.3L's Avatar
I think when i did my old truck i had to loosen up the core support to get those front pins out and she finally came out! I was in the same boat untill i freed up the core support!
post #7 of 8 Old 05-20-2013, 01:24 PM Thread Starter
pittdiesel's Avatar
Awesome thAnks. That's. a huge help.
post #8 of 8 Old 05-20-2013, 02:08 PM
I just did what youre doing now. I know how fun it isnt. got the bolt that holds the stone deflector. upper bracket for core support. bolt behind the door. screws holding the inner fender.
hithebrakes is offline
