lopey idle
i have a 96 powerstroke when on start up it fires up and then has a lopey idle cold or warm you rev it up for about 5 second and then it is great till you shut it off i have clean the ipr did not change anything any help would a big help thanks
any codes at all?? and do you have any way to monitor any sensor readings (scan tool)??
the only code it had was 1705 i have snap on scan tool
monitor ICP pressure, IPR duty cycle, and do an injector buzz test if its capable
i did the injector buzz test and it came back good what should the pressure and the duty cycle be
ICP pressure should be approx 600 psi at idle....700-2800 driving down the road depending on throttle position....minimum 1 volt signal at idle.....with up to three volts if i remember right at wide open....
I would expect IPR duty cycle to be about 7% at idle and up to 75% going down the road...again depending on throttle |
when you get on the pedal it will go up from there |
duty cycle never fluctuates??
so got any ideas on what is wrong with this crazy thing
try rapping on the IPR with something, as hard as you can without denting it. If that doesnt work, try disconnecting the ICP and running it....
