fuel separator drain ball valve leaks
The drain ball valve (plastic) on the fuel separator filter leaked through the top at the handle. Instead of spending the $71 at ford for the cheezy little valve, I pulled it apart, cleaned it and replaced the 7mm o-ring on the shaft. Thought I would pass the info along. Easy fix.
FixitMan
to the forum. Thats some good info and big savings on such a little part. If you have any other words of wisdom, let us know. And once again
COOL TIP AND
TO THE FORUM
Fyi...
In case anyone runs into this problem again, I had a minor issue with leaking fuel a while back, thinking it was the orings on the drain valve I called around and International had the entire drain valve assembly for $15.97 for the 7.3. I thought that was pretty cheap.
how do you change fuel valve on 7.3 diesel
leaky fuel drain valve
As I recall, 4 small star drive screws on back of fuel separator removes it. Take the handle off, the shaft will come out when rotated to the correct key position. There will be a small o-ring on the shaft that has gone flat. I used one from a hydraulic o-ring kit I have at work. Don't use one for plumbing as it wont last with fuel. One of the guys I work with just had the same problem last week. We are now getting fast at self repair. I keep a spare in the glove box now. I see you can get one from International cheap now, ford charges too much. Wouldn't hurt to get a new one from International if you have a parts house close & fix the old one for a spare...good luck!
FixItMan |
See the link in my sig for pics...
Hey, great presentation on the replacement of the o-ring. I did mine almost 2 years ago before I could find that kind of info. Now my memory of the details is gone. This will be a good post for all to read. Thanks for the follow-up. This forum has really been great for us powerstrokers! I just bought an aluminum dif cover for the rear & will freshen up the 140 wt synthetic in it...95K miles on the beast now. Here is the link if you know anyone interested...good price $75.99. eBay Motors: Aluminum Diff Cover Ford Superduty F250 F350 10.25 10.5 (item 260167244660 end time Mar-01-08 14:30:41 PST)
