p1212 touble code - Ford Powerstroke Diesel Forum
post #1 of 21 Old 05-09-2013, 02:17 PM Thread Starter
Ignorance's Avatar
p1212 touble code
Hello all is there anyone familiar with the p1212 code?? I've replace the crank sensor, fuel pump, ipr valve, and did the oil change on it, the truck is also idling like its cammed and when its col it starts up a lil slow but it fires up. but when its warmed up it cranks for a while before it starts. I would think its the oil pump trying to build presser to start it but im not all the way sure. the truck has 270,000 miles on it
Advice would be greatly appreciated
Ignorance is offline
post #2 of 21 Old 05-09-2013, 02:28 PM
JBRIXEN's Avatar
do you have a way to monitor icp pressure and ipr duty cycle?
did you check the wires going to the ipr valve?
95 F350 CCLB, ZF5, 6637, MBRP dp to 4", GTP38, intercooled, 3" plenums, DIY E-FUEL, TE17*, TS 6 pos, 140v IDM, boost fooler, leveling kit, 315/75/16's, boost, pyro, oil temp
JBRIXEN is offline
post #3 of 21 Old 05-09-2013, 05:22 PM Thread Starter
Ignorance's Avatar
no I don't
post #4 of 21 Old 05-10-2013, 09:58 AM Thread Starter
Ignorance's Avatar
when its cold it starts and sounds like it should but the as it warms up it begins to lope
post #5 of 21 Old 05-10-2013, 11:20 AM Thread Starter
Ignorance's Avatar
I just got off the phone with the ford dealer, they said its a high chance that its just the icp sensor so I have it ordered and is on the way and ill let you guys know how it makes out
post #6 of 21 Old 05-10-2013, 12:33 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Does it smooth out if you remove the harness from the ICP?
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #7 of 21 Old 05-10-2013, 01:23 PM Thread Starter
Ignorance's Avatar
don't know, is that something I should try?
post #8 of 21 Old 05-10-2013, 01:52 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
If you unplug the ICP while the engine is running rough the PCM will assume a standard value for the ICP and the engine should go from rough to smooth. If it does then yes it is _probably_ the ICP. Also look inside the ICP where the harness plug was, is there oil in it?
Matt
'97
-Stage II trans.
BigFuel is offline
post #9 of 21 Old 05-10-2013, 02:24 PM Thread Starter
Ignorance's Avatar
ok i tried it, when it was cold it idled down rougher then picked it self up and ran smoother, but I took it around the my park idling and then i tried it again and it didn't do any difference once it got warm. i do have oil in the sensor but not in the electric plus that plugs into the sensor
post #10 of 21 Old 05-10-2013, 02:37 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
I'm not convinced that this is a ICP issue. Without the ability to monitor the ICP, IPR % duty, and the HPO system in general I can be totally wrong here. Before you spend any more money on this lets do some testing.
My instinct here is that you have blown injector o-rings. When the engine is dead cold the oil is thicker (I know you know this already) and is harder to bypass the injector o-rings than it is as the oil heats up. The injector harness has four connection through the VC. With the engine running at operating temp and idling pull each connector and wait one minute. Did the idle change/roughen as the engine got used to not having those two injectors? If you pull one of the connectors and nothing happens (or barely nothing happens) lets go farther.
Matt
'97
-Stage II trans.
BigFuel is offline
