Map sensor - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-08-2013, 07:29 AM Thread Starter
Map sensor
So here's my problem, I changed my map sensor out last night and this morning I notice a big power loss. Why would a new map sensor cause power loss?
caleb2 is offline
post #2 of 5 Old 05-08-2013, 08:53 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 44 Post(s)
The new one can be bad right out of the box. Also, if you haven't changed the rubber line at all it may have cracked when you were moving it around and now you have a boost leak that keeps the MAP from seeing intake pressure. Also, the rubber line from the factory is held on with a crappy spring clamp. You might have pulled it off the plenum. Do you get your power back with the old MAP installed?
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 5 Old 05-08-2013, 09:24 AM Thread Starter
I haven't tried putting the old one back on yet. I'm at school then I work till 6. So when I get home I will try tht
caleb2 is offline
post #4 of 5 Old 05-08-2013, 11:12 AM Thread Starter
I unplugged the sensor and the power came back. So does that mean bad sensor?
caleb2 is offline
post #5 of 5 Old 05-08-2013, 12:42 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
It could be that the new MAP sensor is bad. Are you sure it is the correct MAP sensor (and not something like one for a gasser)? Here's the factory number:
MAP Sensor
(Ford) F4TZ-9F479-A (94-98; digital)
Cheers!
Patrick Feeley is offline
