Hazards dont work but blinkers do - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-30-2013, 08:33 PM Thread Starter
Damaged82's Avatar
So my hazards don't work at all but the blinkers work just fine. Is there a separate relay or anything to look for? Or is the switch just eff'd 97 f350 thanks guy. I'm thinking this truck has a lot of electrical gremlins. I got this truck from my grandfather when he passed and I'm never going to get rid of this truck I just want to make everything functional!
Travis
97 F350 DRW 4.10LS ZF5 ext cab flatbed, tymar intake fpr shim idm mod 3in dp edge programmer
97 F250 E4OD 3.55LS ext cab 5in exhaust fpr shim
Damaged82 is offline
post #2 of 3 Old 05-01-2013, 08:19 AM
Quoted: 48 Post(s)
They're on two different fuses, so that's the first thing to check. They also have separate flasher modules. One's on the side of the (interior) fuse box that you can see, and the other is on the side you can't see; I forget which is which, but you could swap them and see if the problem "moves".
madpogue is offline
post #3 of 3 Old 05-01-2013, 03:13 PM Thread Starter
Damaged82's Avatar
Thank you! I had no idea there was one on the inside. That was the fix!
Travis
