ether or not - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-29-2013, 08:20 PM Thread Starter
ether or not
Hey got a95 PS that will not crank unless motor is warm changed gpr and tested w/ meter its good just bought truck 3 weeks ago don't know much about diesels but I think it maybe glowplugs hope they didn't use ether on it . Looking for any comments or helpful advice thank you in advance
95 f250 beast is offline
post #2 of 5 Old 04-30-2013, 07:43 AM
Patrick Feeley's Avatar
Quoted: 10 Post(s)
Make sure the batteries are good (have them load tested independent from one another). Have the starter checked (they do degrade over time). Clean all ends of the battery/starter cable connections. Check all the injector/glowplug harness connections at the valvecovers (there are two connections per side, so four total) for any evidence of melting/burning. Are you getting white smoke out the tailpipe when trying to start it cold? Cheers!
Patrick Feeley is offline
post #3 of 5 Old 04-30-2013, 09:08 AM Thread Starter
Hey Patrick already replaced 1 battery also cleaned and coated posts with axle grease and replaced a battery cable and yes I get plenty of white smoke when trying to cold start
post #4 of 5 Old 04-30-2013, 08:14 PM
kkbodyshop's Avatar
glow plugs
94.5 f350 dually
216k miles
straight piped
intake
fuel shim
ts chip
kkbodyshop is offline
post #5 of 5 Old 04-30-2013, 08:18 PM
usnavyad's Avatar
Feedback Score: 3 reviews
ether is like crack for a diesel they get addicted lmao
04 harley davidson f-250 arp headstuds oem gaskets,sb intake,edge cts egt probe,sct sf3 idp tuned/ php tuned,blue spring,zerex coolant swap,mbrp 5 inch xdp 6 inch tip,sinister egr cooler,new oem oil cooler,atlas 40 ficm,Painted cac tubes 7.3l wire loom,Diesel site coolant filter
GPDA's other shawn
usnavyad is offline
