Exhaust temps, what is normal - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-22-2013, 08:02 PM Thread Starter
nohsp4u's Avatar
Ok, as stated many times over, i am not a diesel mechanic or even good a faking it to date but, i want to ensure my girl lasts a long time.
Installed on this rig is a banks power pack system, or so says the previous owner. I have a gauge for Pyro, exhaust temp. Is this the same is the EGT's everyone talks about?
I ask because i noticed, as i drive up a hill about 3% for less than 400 feet, my girl goes from 350 up as high as 750 at a speed of 35-40 mph. I noticed she climes high when i dump on the go pedal, i understand this is the reason for heat but, it seems like it goes higher than it did last week.
As highway speed 65-70 Mph with cruise on and RPMs just shy of 2k, she runs in the high 600's.
Can someone explain what i should expect? Keep in mind, i do believe the gauge is installed wrong. Everyone says to install the probe in the exhaust manny but, mine per the Banks book is installed in the top of the turbine outlet pipe. Should i change location or just know it is about 200 degrees shy of the truth, which would concern me more?
I plan to blank the cat when i get money for a delete pipe and i know this will help a little, i have the inner cooler and also plan to buy a 6.0 fan and install. Any other ideas to lower EGT's, if this is what my gauge is telling me.
Thank you all
1997 F-350 XLT Lariat Crewcab long box 4x4. Oxford white with an ugly green. 133xxx miles. Hide away goose neck, banks turbo, exhaust, inner cooler, intake filter and gauges.
nohsp4u is offline
post #2 of 7 Old 04-23-2013, 12:08 PM Thread Starter
nohsp4u's Avatar
Is there anyone can help me with this?
nohsp4u is offline
post #3 of 7 Old 04-23-2013, 12:13 PM
dannanw's Avatar
Quoted: 54 Post(s)
Garage
egt's shouldn't go above 1250-1300...with out a "hot" tune or towing heavy most people wont go even close...pre or post turbo are your numbers?
BTW dump the banks chip (if it has one) and get a TS/DP chip.
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #4 of 7 Old 04-23-2013, 12:22 PM Thread Starter
nohsp4u's Avatar
Banks chip is history by way of a computer replacement in 08 by PO and chip no works. A TW 6 pos is in my sights when the Homestead CFO authorizes.
My gauge is hooked up to read post turbo. Is that correct or should i relocate to the exhaust mannifold? If it does not matter i would rather not move it.
nohsp4u is offline
post #5 of 7 Old 04-23-2013, 12:32 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I would suggest moving it, matt aka bigfuel post a pik of a cummins on an engine load stand and showed something like 500* difference between pre and post turbo, and I have noticed in my trucks that it is anwhere from 300-600* difference pre and post turbo, so I say move it to the manifold, and anything north of 1250 you start melting things if you sustain that to long, if you want to cool it off even more try an intercooler and water meth injection, I cruise at around 600-700* in my 97, and before my intercooler it was around 750-800, I stay at 75-80mph at those temps
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #6 of 7 Old 04-23-2013, 01:17 PM Thread Starter
nohsp4u's Avatar
Got the inner cooler. removing CAT soon, and have no idea about water meth injuection. In my neck of the woods, if i say meth too loud i will tackled to the ground my both swat and the meth heads. LOL i suppose i will move the probe, i knew that was coming. Looking at your temps, i am running the same, just not reading from the same location. I am in for a big surprise when i move it.
nohsp4u is offline
post #7 of 7 Old 04-23-2013, 01:58 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
more than likely you would be, but the main thing is seeing the temp before the turbo so it don't melt, as oppose to after you've already ran that temp plus through the turbo
I should have read your sig
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
