truck seems to be missing - Ford Powerstroke Diesel Forum
post #1 of 11 Old 04-21-2013, 12:22 PM Thread Starter
Hey everyone as im driving my truck seems to chug an miss enough to make it hard to accelerate. Im thinking injector harness. But i changed them under the valve covers about 10000 miles ago. Maybe a external harness pig tale? I need input asap
jakesharp22 is offline
post #2 of 11 Old 04-21-2013, 10:22 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Pull the plugs from the vc harness and look at them, also check hpo res to make sure it's full
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 11 Old 04-22-2013, 02:53 PM Thread Starter
Okay today i ohm'd the vc pinns for injectors all were at 3.1 3.2 ohmss hpo resivor is close to full. I changed all vc pigtails no change hooked up the snap on solous pro an no engine codes while at idle it read that i have 746psi of hpop and all buzz tests on injectors were with in spec. Now symptoms has a hard time starting after sitting over night sometimes many attempts to start. Befour it does also it has a a heavy blue smoke for about 5 mins then clears up to a faint blue smoke but when you syomp on it agian heavy blue. It has a romp at first start also. Has good fuel pressure 46-67 i need help im stumped..
post #4 of 11 Old 04-22-2013, 03:59 PM Thread Starter
Does anyone gave any ideas? Injector o rings? Would they maybe cause this?
post #5 of 11 Old 04-22-2013, 04:09 PM
The Maddawg
maddawg89's Avatar
Quoted: 290 Post(s)
Feedback Score: 3 reviews
Sounds all too familiar.... That miss while driving and hard to accelerate anyway...I'm searching for my issue as well....
2005 F250 6.0 Powerhouse Lariat
Bully GT Platinum with Quick Tricks
Bully Dog intake
Everything else stock.
Moto Metal 18in rims wrapped in 275/70 Mud Claw Extremes
2003 F250 cclb flat bed.
All stock 7.3 turtle
maddawg89 is offline
post #6 of 11 Old 04-22-2013, 05:11 PM Thread Starter
Im leaning towards idm. O rings, ipr, or pcm. Idk wht else it could be th truck has 140,000 miles
post #7 of 11 Old 04-22-2013, 05:38 PM
OL' OutLaw's Avatar
if you have a spare ICP, change it out....or swap in one from ur buddy's truck...
you should have around 500lbs HPOP at idle....
'97 Centurion. F350 4x4 CCLB
Full Force 180cc Stage I's, D66, SRP-1.1, ARP, Banks IC, DIY E-Fuel, EBPV Del & Gut'd Ped., BD Exhaust Brake., SD IDM, HPX, BstFoolr, 4" DP - 4" exh,
6.0 Fan, 180 T-Stat, DIY Don.105006 AF, CCV Mod, BTS, W/ SD Trans Lines, Tru-Cool Max, PML Trans Pan, Bumper Mod, IssPro Gauges, Fluidampr, Mellings LPOP.....
Tuned by "The WildMan".
OL' OutLaw is offline
post #8 of 11 Old 04-23-2013, 04:23 PM Thread Starter
Well did more diagnostics today and i have come to the conclusion that #3 injector is shot so ordered a new reman for 165 bucks an will be here tomorrow. And im re o ringing the other 7
post #9 of 11 Old 04-25-2013, 02:56 PM Thread Starter
Okay guys new injector instaled an new orings on the other 7. And its running great but when ever i shut it off its hard to restart it takes multiple attempts to start but once it does it runs great. Any ideas? Need quick response
post #10 of 11 Old 04-25-2013, 03:57 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
have you tried the IPR yet? y would you replace the injector if they all tested fine?
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
