2 Problems - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-07-2013, 08:34 PM Thread Starter
pwrstroke84's Avatar
2 Problems
1996 F-350 OBS PSD 150k.
Problem #1: Won't go into 4wd. Drive shaft spins, front axle u joints spin one at a time (I am assuming that is correct). It has aftermarket automatic hubs (yes I know they are junk, they came on the truck) and so I am guessing that it is the hubs that need to replaced? Is there some way that I can confirm this?
Problem #2: Check engine lights comes on when first started. Doesn't seem to matter when temp I start it at, but it's just when it is "cold" or first starting it up. If I drive it and shut it off then turn it right back on we are good. After it runs for a bit it turns off. Also it seems that it doesn't have as much power when the light is on and it idles a little lower when the light is on. Short of plugging it in to read codes anything else that I could try, that maybe you guys have run into?
Thank you very much for all the help in advance!
pwrstroke84 is offline
post #2 of 3 Old 04-10-2013, 08:35 AM Thread Starter
Anyone? Just really don't want to drop $250 on new hubs if they aren't the problem.
Thanks.
post #3 of 3 Old 04-10-2013, 11:35 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 57 Post(s)
I'm not a 4x guy but PM me an email address and I'll send you Fords auto hub removal and installation guide. My first thoughts are to have you remove the hubs and inspect/grease them. Install and try the operation again.
Without a scan tool its kinda hard to find out why the Engine Error light is on. I would first suspect that it is an ICP error. Maybe you have a weak HPOP and the PCM can't keep the high pressure oil up.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
