steering wheel goin to the right - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-02-2013, 01:36 PM Thread Starter
ole96stroker's Avatar
Alright so ive been having a steering problem and my steering has been pulling to the right really bad so I jus thought it was the brake caliper sticking cause it was, so i put all new calipers on it and a front end alignment.everything on the front end is good,Anybody have an idea of what it could be thanks
******1996 ford f250 powerstroke 5 spd 4x4******
***170,000 miles, ts 6 pos, intake, exhuast***
ole96stroker is offline
post #2 of 5 Old 04-05-2013, 07:37 AM
JBRIXEN's Avatar
did you take it to a shop to have it aligned?
check for a separated tire.
95 F350 CCLB, ZF5, 6637, MBRP dp to 4", GTP38, intercooled, 3" plenums, DIY E-FUEL, TE17*, TS 6 pos, 140v IDM, boost fooler, leveling kit, 315/75/16's, boost, pyro, oil temp
JBRIXEN is offline
post #3 of 5 Old 04-05-2013, 09:55 AM
Quoted: 60 Post(s)
F250 or F350?
madpogue is offline
post #4 of 5 Old 04-06-2013, 08:05 AM
sometimes your tires can play a part. Even new tires can cause alignment issues. Obviously not top shelf rubber.
hithebrakes is offline
post #5 of 5 Old 04-23-2013, 10:44 PM
Blazin8556's Avatar
Can the radius arm bushing do this? Mine is pulling and I know my bushings are shot
1995 F350 XLT|DRW|7.3L Powerstroke|1.0 turbo|3" Diamond Eye Downpipe|Straight Piped|EBPV delete|DIY 6637|RiffRaff turbo inlet boot|203* thermostat|IDM mod|CCV|Built E4OD|Derale Trans Pan|Trans Temp Gauge|Explorer RAP RKE. Traded for a chevy
2007 F350 Lariat 6.0 . under the knife already
Blazin8556 is offline
