Special PCP - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-25-2013, 08:25 PM Thread Starter
Quoted: 3 Post(s)
Special PCP
Hey everyone, a friend of mine has a 97 ccsb Powerstroke. The truck has a little over 100,000 miles on it and is bone stock. He tells me that it has special PCM that was only put in a few 97s. Has anyone heard of this? The problem is that it keeps eating up PCMs and it is just sitting in the barn. Is there a way to solve this problem? Thanks in advance
2000 PSD, 4in Exhaust, 6637 Intake, Zoodad, TS Canned Tunes, JWVB, Billet Wheel, FRx
ilovemy7.3 is offline
post #2 of 7 Old 03-25-2013, 10:51 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Check the wiring, and if your friends psd has a blue sticker on passenger side valve cover stating its compliant with California emmisions, his PCM is special, if not then his is just as cool as the next 94.5-97 obs
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 7 Old 03-26-2013, 09:41 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Second. We know as we have them also. Tell your friend to NOT buy PCMs from PCM Exchange. They are crap.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #4 of 7 Old 03-26-2013, 06:27 PM Thread Starter
Quoted: 3 Post(s)
I'll check the connections. Is there a way to stop the PCMs from going out? Could I send it to say PHP or TW to have it looked at?
post #5 of 7 Old 03-26-2013, 07:43 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
For physical damage you are pretty good with taking it to an old TV repair shop. For software damage you could take it to Ford for a re-flash. PHP's or DP Tuner can do that also but they would be more expensive then Ford.
Matt
'97
-Stage II trans.
BigFuel is offline
post #6 of 7 Old 03-27-2013, 02:28 PM Thread Starter
Quoted: 3 Post(s)
Does anybody know what causes this or how to stop it from continuing?
post #7 of 7 Old 03-27-2013, 03:19 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Generally electrical shorts in the main harness. Diesel fuel is corrosive to wire isolation and guess what...the main harness runs right under the fuel bowl. There is a 99% chance that the engine has had at least one fuel leak at one time or another. Without opening the harness and washing it out the diesel continues to eat the insulation. Other trouble spots are shorts under the valve covers.
Matt
'97
-Stage II trans.
BigFuel is offline
