Crew cab rear window not working - Ford Powerstroke Diesel Forum
Old 03-13-2013, 02:33 AM
As the title says my driver rear window is not working.. it's getting power and is grounded properly so my guess is that the motor is bad ? Also on the passenger rear goes down perfectly but will barely go back up
Old 03-13-2013, 09:26 AM
Left side one doesn't work either from that door or from the "captain's" controls? Check the wiring as it passes through into the door from the B-pillar. Common pain point on the CC trucks.
Old 03-13-2013, 11:26 AM
On the one that barely goes back up, you can check to see if the plastic "dogs" in the motor gear are chewed up. You can get replacements in the HELP! section at most autoparts places. Some folks will use 5/16" nuts instead of the dogs. The moto can be removed from the regulator by removing the 3 screws holding it on, but you need to drill holes in the inner door sheet metal to access them (fairly simlple to do). Cheers!
Old 03-16-2013, 01:06 PM
Rear Window Problem as well
Has anyone seen documented on the forum with either pics, video or simply text what the steps are to get access to the motor, remove it and then replace it?
I am having same issue but pax side.
Thank you!
