help truck idleing funny
95 f350 turbo 214k miles truck is stock other then straight pipe an napa 6673 filter. truck shakes when idleing an smoothes out when you give it a little throttle. it has felt like it has died a couple of time driving down the road but is still running . i replaced the cps today. when i unplug the icp it runs the same . sitting at the stop light it ildes up a down a lil like its under a load. the icp wiring lookg good an no oil is in the plug. im at a lose with it. please help
it has a new ebps an i have cleaned the tube
idle smoothes out when i give it throttle at 2 grand rpm. it has 2 new batterys but volts guage is dropping. battery light is blinking when i rev it up
Does the volt gauge go back up after the GPs time out (aprx. two minutes)? If not, alternator is your prime suspect.
had my truck checked out 2 day . guy said i need injecters. he also told me to put a qt of marvel mistery oil in the oil an sum trans fulid in the diesel tank an drive it. i have done that an it seams to run a lot better. he gave me a great price on a set of stock injecters $1600 an a set of stage 1S $1650. has anyone ever heard of the mm oil trick?
