96 shifter wont come out of park
The column shifter wont come out of park. I have no idea if its related but the abs light ( I have no abs ), starts flashing when i press the breaks. Whats going on?
Thanks |
Re: 96 shifter wont come out of park
Check your fuses. Had this happen in my 150. Maybe it's the same issue. See if your turn signals work.
No signals. Which fuse? They appear fine but I did not pull all of them yet.
Found it. Blown hazard fuse. Thanks
No problem. Glad you found it. It may happen again. Had to go over the entire engine and check all the grounds because I was getting shocked when touching the throttle cable under the hood. Just something to think about even though this was a gasser.
