Ill tell u everything Iv done and replaced glow plugs and relay pcm batteries starter ipr icp uvch fuel pump injector orings flushed fuel system dropped and cleaned tanks ran injector buzz test and Koeo test systum pass I'm building up 2800 icp and 50 percent on ipr the truck fires and shuts down immediately any ideas would be greatly appreciated
All that work and you didn't replace the CPS?
Yep forgot to put that first thing I did
Check your grounds?
Battery grounds or what? The truck almost runs its so annoying. I don't know what else to do any info would be greatly appreciated
Fixed yet? What happened when it first quit? Were you driving or just trying to start or what? Is it cold? Do you have a block heater? (NOt sure of your location) if that is an issue). I know that my truck will start and quit if it is not plugged in. If I plug it in it starts and runs good but I'm in Canada and it gets below freezing quite often in winter.
Check fuel pressure, is it consistent? Sounds like it could be running out of fuel for some reason. I guess you could check HPOP (not sure if your going off of computer data or mechanical guages)as well with mech guages-put guages in line and watch what they do(3000psi) guage at least, 4-5000 would be better as pressure does get up there if you rev it up. I used a #6 JIC running Tee and adaptor FM #6 JIC and FM pipe for guage($12) plus a guage (had already) and I happened to have a hose (3000psi w#6 JIC M& FM ends) about 3' so I could read it in the cab while cranking. I hate to see someone replace a bunch of parts that didn't need to be. Sometimes need to "see" or have more info of what is going on in the engine before replacing parts. I haven't done a lot with PS diesels but have done fair bit of mechanic work. Fuse 22 on my truck went a couple times but then it didn't fire at all. Could be electrical issue, if it is that wouldn't be fun. Should be able to wiggle and pull on wires and hope that something shows up. |
