96 7.3 fuel leak? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 12-14-2007, 03:29 PM Thread Starter
inkedinmiami's Avatar
Unhappy 96 7.3 fuel leak?
I've noticed my 1996 7.3 lacking power from time to time and I smell fuel. I also noticed fuel dripping on my driveway. I looked under the hood and there is fuel laying under the turbo. Everything from the turbo hoses to the oil drain plug is wet.
Where to start?
inkedinmiami is offline
post #2 of 12 Old 12-16-2007, 06:11 AM
7.3 tech, supporter
fordnut85's Avatar
Firdt thing you wanna check is the fuel pump down in the valley and the hoses running to it. When the fuel pump goes bad it will leak from a weep hole on the bottom of the pump. It could also be o-rings on the bottom of the fuel filter. First thing I would do is clean the valley best you can and run the truck and try and pin point where the fuel is coming from.
Duane
1994.5 F-350, PSD, 5spd, Crew cab, 2wd, DRW
10k mod
Idle control mod
homeade exhaust brake
Tymar intake
fordnut85 is offline
post #3 of 12 Old 12-21-2007, 05:22 AM Thread Starter
Thank's. After looking and drying I took advantage of the bb to boost the fuel pressure hoping this would help the leak along. Boy was I right. The leak is coming from the fuel line collar? Where it attaches by a nut to the pump. Does any one know what size the nut is and if it can be tightened with out removing the turbo?
post #4 of 12 Old 12-21-2007, 05:23 AM
ADMIN AND TECH
SCUFFY828's Avatar
that bolt is an 1 1/4 in size
ITS STOCK
SCUFFY828 is offline
post #5 of 12 Old 12-21-2007, 05:28 AM Thread Starter
Great, is there an o-ring, gasket or something ther that can go bad? or is it just tighten and it seals?
post #6 of 12 Old 12-21-2007, 06:10 AM
ADMIN AND TECH
SCUFFY828's Avatar
if you try and tighten it and it doesnt feel loose yes there are two metal o-rings on each side of that bolt, try tightening first
ITS STOCK
post #7 of 12 Old 12-21-2007, 07:32 AM Thread Starter
Worked like a Champ. It was just a little loose. It seemed to twist the fuel lines just a touch but shouldn'd hurt anything. I'll keep an eye on it and change the metal o-rings if needed.
Thank's,
This site is great thanks to people like you!!!
post #8 of 12 Old 12-21-2007, 07:40 AM
ADMIN AND TECH
SCUFFY828's Avatar
glad you got it fixed
ITS STOCK
post #9 of 12 Old 12-22-2007, 09:56 PM
97jdpowersmoke's Avatar
i had the exact same prob the nut was loose bout 1/4 turn but i still have a puddle in the valley right in front of the turbo
parting out 97 F-250...
selling 97 dodge cummins 12v with a vgt...
LOOKIN FOR A 97 CC.SB. POWERSTROKE!!!
97jdpowersmoke is offline
post #10 of 12 Old 03-20-2008, 04:06 PM
are the injectors from a 94 7.3 the same as 96 7.3
annabellasmom is offline
