Can someone tell me what this is leaking? - Ford Powerstroke Diesel Forum
Old 01-31-2013, 11:03 AM
Hey can anyone tell me what is leaking out of here. I'm covered in diesel. Just changed my lift pump. It went
Anyway I knew I had this problem with the slit in the inspection cover. It drips when running. Missing bolt also. It def isn't a tight seal. But for the life of me can't tell if its diesel/oil/teams fluid.
No big oil leaks or fuel leaks. Besides the lift pump which is fixed. Sometimes this thing blows through oil in the winter. Not sure if that's it or not. No pools or anything. Much appreciated. Can someone tell me what this is leaking?-imageuploadedbyautoguide1359662542.958448.jpg
Crap I just realized that is a horrible photo. Ill try and grab another when I get home here in a few.
Sent from AutoGuide.com App
Old 01-31-2013, 03:47 PM
I have no idea what that picture is supposed to be showing. The normal fuel leak is from the bowl drain valve, it runs down the valley and comes out near the transmission inspection cover. Could also be one of the rubber lines to the bowl that has cracked with age.
Old 01-31-2013, 06:56 PM
Enable the flash on the camera. You can just make out that the shot is forward from the right rear, starter, oil pan, part of the tranny; but it appears to be lit from the parking lot lighting, which doesn't provide any clue as to color.
Have you tried getting some of the leaked fluid on a _white_ paper towel? That would clue you in as to its color.
Old 02-01-2013, 08:22 AM
Sorry forgot pic. On it in a few hours. Will post. And put on papertowel.
Old 02-06-2013, 06:21 PM
Exclamation leak
i just fixed the same problem today, look in the valley behind your fuel filter on top of the engine, if theres fuel in it then take a pressure washer and spray it all off, drive it around the block a few times to evaporate all the water then shut the engine down and look again.... take a inspection mirror and look under the pump, there is a weep hole there. if it isnt dribbleing then check your fuel filter gasket, mine didnt even look like it was leaking. but when i took it off i had found that over time the gasket dried in one small spot and eventually built up enough fuel in the valley to let it drip down the back of the block and into the inspection plate on the trans bell house! good luck my friend!
Old 02-06-2013, 06:22 PM
Lightbulb also
also you could try putting baby powder in the valley after you washed it, you will see where its leaking from in the white powder!
Old 02-06-2013, 07:02 PM
Awesome advice. Two great ideas. Trying them both as soon as it gets above 32 degrees here in Ohio
Old 02-06-2013, 07:04 PM
Lightbulb weather
actualy dude, i found that i wish id have cleaned my engine off drove it around then didnt check it but parked it real quik, because it leaked more in the mourning at cold start then it did when it was hot, you would probably get a faster and more direct location of fuel if you did that!
Old 02-07-2013, 08:32 AM
It may be a leaky line from the lift pump to the filter housing. I've seen the fuel heaters and the drain valves leak at times also.
Old 02-08-2013, 04:24 PM
Mine is doing the same thing and I've taken the fuel bowl out and cleaned it up checked for leaks and inspected it when the truck was running. After I put that back in and started the truck I could see rivulets of fuel rolling away from the lift pump. I just can't find the exact area of where it is leaking on the pump. What kind of weak points do they have?
