97 PSD lagging and humming grinding noise - Ford Powerstroke Diesel Forum
post #1 of 11 Old 01-24-2013, 11:14 AM Thread Starter
I have a 1997 PSD all stock with 194,XXX. E40D no idea if it has ever been rebuilt or not.
since the cold has set in the truck has been running a bit rough. In all gears the truck will consistently make a humming/grinding noise and slow the truck down. it is only at a certain rpm in each gear. i can even hear it do it when idling. after the truck is warm it will still do it unless i shut it of and let it sit for maybe ten minutes and then drive again, and even then it still does it. i have to get on it for it to go away and it makes her real hard to drive. Any ideas? i will try to make a video of it tomorrow morning when i go to work, as it is sort of hard to explain. I am thinking it is the trans because it does shift a bit hard, but maybe the turbo. would EBVP have anything to do with it
all_stroked_out is offline
post #2 of 11 Old 01-24-2013, 04:39 PM Thread Starter
Any ideas? I have a video but I am unsure of how to upload it here
post #3 of 11 Old 01-24-2013, 05:39 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
Does it sound like marbles in a coffee can? Cheers!
Patrick Feeley is offline
post #4 of 11 Old 01-24-2013, 05:47 PM Thread Starter
No more like sandpaper against metal!
post #5 of 11 Old 01-24-2013, 06:00 PM
Quoted: 50 Post(s)
Does it happen when coasting in neutral?
madpogue is offline
post #6 of 11 Old 01-25-2013, 08:30 AM Thread Starter
No it does not, only around 1100 to 1500 rpm in any gear besides neutral. I am going to changes the trans filter and fluid and see if that helps at all. The fluid looks good and light red though...
post #7 of 11 Old 01-25-2013, 08:42 AM
Quoted: 50 Post(s)
Okay, just wanted to establish that it's not something further down in the driveline (diff, brakes, etc). Hmm, torque converter maybe?
madpogue is offline
post #8 of 11 Old 01-25-2013, 08:53 AM Thread Starter
7.3 Powerstroke issue - YouTube
Here is a link to it
post #9 of 11 Old 01-26-2013, 02:07 PM Thread Starter
bump bump bump
post #10 of 11 Old 02-08-2013, 01:11 PM Thread Starter
Recently, i removed the exhaust from the cat back and the sound is amplified by 10 fold. I am leaning towards a torque converter, but i am unsure as to why the noise would get WAY louder? ANY suggestions would be awesome. Also i can post another video when i get home without the exhaust on if needed...
Tucker
