How Does An Alt. Go Bad - Ford Powerstroke Diesel Forum
Old 07-28-2006, 11:27 AM
Send a message via MSN to redneck_1086 Send a message via Yahoo to redneck_1086
Last week i put a 6 pos. chip in and ran w/ it a couple days then i went on vacation, well today i got back and went to drive my truck and the batt. light is on. I replaced my alt. about 2k miles ago and it fixed it. My alt. can't be bad already can it
Aaron
Old 07-28-2006, 11:38 AM
I don't know nuttin....
Have your batteries tested. If you have one bad one and one good one, your alternator will work overtime trying to keep up and burn out your voltage regulator.
I found this out the hard way and had to replace my batteries and alt.
Test your Batteries and if ones bad, replace both!
Old 07-28-2006, 12:42 PM
bad batts. will kill a good alternator.
Old 07-28-2006, 04:24 PM
High resistance in the wiring will also. The big cables that run to the starter, batteries, and altenator should have ZERO resistance. If a cable that big has any resistance at all, its just a big energy sucker......test the batteris and check the cables VERY well......
Old 07-29-2006, 09:57 AM
After i made this post i went out and drove some more and the light didn't come on again but today i drove it and it came on for about 10 sec. then it went off. It sounds to me like a conection so i'll check that sometime. Any other sugestions?
