New guy with a electrical question - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-09-2013, 07:40 AM Thread Starter
I recently bought a 96 250 crew cab long box with dual fuel tanks with 230,000 on it. This is my first diesel btw and I love it so far. The problem I am having is with my charging system. My battery light keeps flickering. The guy I bought it from replaced the alternator not to long before I bought it. Now some times the light will flicker on a smooth road or a bumpy road. It will also flicker when I'm jus sitting there idling. (Which means the problem is close to the engine I'm assuming) if it starts going crazy if I get on the gas and accelerate hard the light goes off.
The truck did quite on me one day after the light was flickering for a whole and I went and bought a voltage gauge because the stock on doesn't work. I am trying to figure out where to start diagnosing this. Ive had the truck running with my wife in it and I've wiggled everywhere and harness I could find and the light didn't illuminate at all. Am I looking in the wrong place? I also had autozone test the alternator on the truck and they said they couldn't guarantee the accuracy because of the dual batteries.
I'm guessing I'm looking for a short or a bad ground somewhere. I'm just not sure if its under the hood.
Thanks for the help.
Impulse138 is offline
post #2 of 6 Old 01-09-2013, 08:06 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 49 Post(s)
Here is the charging schematic. Have you isolated the Batteries and tested them individually? :
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 6 Old 01-09-2013, 08:21 AM Thread Starter
Thanks for diagram. And I have not tested both batteries individually.
post #4 of 6 Old 01-09-2013, 02:19 PM
Chop's Avatar
The single wire on the top of the alternator can be disturbed by the heater hose or a somewhat loose connection .I think it's called the "stator " wire
1996 F250 PSD Crewcab,auto,D 60 swap,3" dp, DIY air 4X4 Centurion
Chop is offline
post #5 of 6 Old 01-09-2013, 02:51 PM Thread Starter
Looking at that the hose is touching it and it is a little loose although when wiggle it the light still dosent come on.
post #6 of 6 Old 01-13-2013, 01:55 PM
chass350's Avatar
i had the same problem, the white wire in the pigtail on the top of alternator was loose..it was loose in the pigtail...
1997 Ford F350 7.3, 172,000 miles
Banks Big Hoss chip level 4 (100 HP)
Triple gauge pillar mount
Pyro gauge, Boost gauge, Trans Temp gauge
Banks 3 inch down pipe
straight pipe, cat ran off
33/12.50/16.5 BFG Muds
Detroit Lockers
chass350 is offline
