- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
So last weekend I replace the fuel pump because it had gone south. I replaced the hoses (got them from the dealership) tightened it all back up and dry as a bone for a couple of days. This week there is fuel in the valley and under the truck!!!
I cleaned the fuel bowl out, checked my repairs on it from a year ago, and it looked solid, hoses are tight, banjo fitting tight as well. I haven't had a chance to look at the engine while it is running and see if I can spot it. However the fuel is up around the fuel bowl. A neighbor of mine and PSD owner speculated that maybe there is a small crack in the fuel bowl and when it gets hot there is a slight expansion and subsequent leak. It sounds plausible to me.........anyone else??? Thanks, Craig |
| Sponsored Links |
Have the same problem I am in the process of replacing the fuel filter housing (fuel bowl) right now. Got the part from Oregon Fuel Injectors (google) about $100 less then from ford, remember to order 3 hoses you need with it, they will know the three you need all short 2 at 2" and 1 at 3" they are silicone fuel lines.
I appreciate these new leads as to the possible origins of my continued problem. Thanks Craig |
UPDATE The leak is coming from the hose that attaches to the fuel pump. The hose clamp won't get tight enough to stop the leak. It is stripped out I guess. It will only get so tight.....pop...and then back to being loose. Apparently, someone (ME!!!) didn't pay attention and put on all new hose clamps (or maybe I am the only guy in the world who got a bad hose clamp) ![]() ![]() ![]() . So am I totally screwed and have to take the bowl off/out to put one lousy hose clamp on??? Is there anyway around this or am I just sitting here typing and putting off the inevitable? Thanks, Craig |
UPDATE Never mind the small leak from the fuel bowl to the fuel pump. I have a bigger fish to fry. There are 2 fuel lines at the front of the FPR assembly are leaking (i.e. spewing fuel). They run from the FPR to each head, when I removed the plastic protective sleeve I saw how cracked and worn they are.. The passenger side looks fairly easy to remove, however, the driver side is turning into a nightmare. To get to the end of this line I have had to remove the A/C compressor, and now have to remove the bracket that holds the A/C compressor and power steering pump. Has anyone done this and how do you get the bracket and power steering pump off? Any help would be greatly appreciated. Also, 2 questions: 1) When I get new lines, should I get braided lines as I don't care to go thru this again. 2) Am I fixing one leak and causing more pressure to build exposing weak lines? It seems as though I have been chasing fuel leaks for a couple of weeks now. I would love to post pictures but the computer and the camera aren't playing well together and are low on the priority list. Last edited by HappeetxnR.N. : 11-04-2007 at 08:16 AM. |
![]() ![]() ![]() ![]() ![]() ![]() My quite version of a rant.Ok so I still have my fuel leak(s) and since i am off this week I am removing the fuel bowl AGAIN. This time EVERYTHING gets replaced. Anyways the only reason I am bringing this back up is for moral support. I have already started pulling it a part. Also, I think I am about ready to commit to getting Bean's electric pump set-up for this truck. Since this truck is a keeper I think the price will be worth it not to have this headache anymore! Thanks for putting up with the rant and frustration. I still thoroughly enjoy my truck in spite of this continuing problem. Craig |
| Sponsored Links |
